Start commands with Google Home Assistant
I’ve been setting up my complete Athos Homey system and i’m quite fan of it. Good job there!
I’d like to initiate some specific flows which start with a voice command. For example: “good night” should result in shutting down the tv, turning off all lights, …
So I start a flow with “if” and then choose “speech” where I fill in this specific word.
  • But how should I trigger this with Google Assistant? Can I say “Hey Google, xxx” or does it still has to be “Hey Google, ask Homey to xxx” ?
Can this be in dutch or only in english?
Home Assistant should already be properly connected and synced.
Thanks!
I’ve been searching tons of things, really been reading a lot… And I’ve seen that it should be possible, but it’s not working for me.
He listen to commands set in IFTT, but not for custom commands set in Homey.
Check this example: it’s a dutch sentence which couldn’t be confused with something else or a default google sentence - but still it does nothing: https://www.screencast.com/t/5RvnKvpq
Any idea?
OK, dus je moet een virtual switch aanmaken? Ik vind echt geen deftige documentatie hoe ik het kan opzetten, en “out of the box” werkt het écht niet bij mij … :slight_smile:
Too much to read. Can you make it more compact?
Can you make a video on this
Such step by step example clarifies a lot. Let’s have more of those! Thanks
Thanks for the walkthrough.
For some reason the virtual device will not show up in home assistant, any idea why?
Sommer devices will come up but somer won’t.
I followed the walkthrough for creating a flow that I can use in Google assistant but if i use a virtual button it won’t show up. A virtual switch will though
Yeah it needs to be a virtiual switch, buttons won’t work.
Just awesome thanks…
Hi Moeten,
This article is actually outdated. Nowadays, you are ablo to say, ik googlez start “scene name”. Works like charm!
