SONESSE 40 Zigbee- Can't add to Homey Pro?
Hi
I’ve just had Somfy Sonesse 40 Zigbee Roller blinds installed but I’m struggling to add these to my Homey Pro. I had to purchase the Somfy Tahoma app to control the roller blinds through their add which also supports Home Kit so I’ve got them integrated with Home Kit but I want to see them in Homey Pro.
I’ve tried with the 2 Somfy apps but neither works, I paid extra and upgraded over RTS motors so I could adjust the exact opening of the rollers hoping it would be very easy to add to Homey but I just can’t add them- I’ve tried adding them through Zigbee and putting the motor into pairing mode by holding the button down but it still doesn’t show. Seems like Somfy has closed their Zigbee network off?
This talks about Sonesse 2 motors, but the same probably also applies to yours:
https://www.reddit.com/r/ZigBee/comments/1dyk15q/comment/lcksd10/
TL;DR: these devices, by default, run their own Zigbee network. You need to send certain commands over BLE to turn off this network so it will pair with other Zigbee networks.
However, you will still have the issue of there not being a Homey app for these, so you won’t be able to use them with Homey anyway.
