Somfy Connection kit
Hi Adrian! You helped me also a lot with your app and with the pairing problem. When reading this topic again a few month later I had an idea, that may come in handy.
Probably this problem won’t get easier over time, so why not embrace that fact and handle it with a little les ambitious goal. Indeed it would be nice, to have a unique fitting set of icons and images for every product, but that turned out to be rather impossible.
Let me give a short recognizable example:
The problem shows similarities with the pairing of TV-remote controls and settop-boxes. A scenario with many brands and many different products with their own capabillities. So in that scenario the brands came up with “installing-code-lists”.
So when you try to pair your remote (so you can control both you settopbox and the tv), they let you press a standard set of buttons (e.g. the blue-knob and ok-knob for 5 secs, to enter the programming mode and than a 3-digit number with represents the most common combination for that brand. (a bit like this list: https://www.caiway.nl/klantenservice/televisie-en-radio/tv-codes).
After that you are asked to test if it is the right code, by turning your tv on and off, check if volume and channel up and down works and than you are a good to go. If the tv doesn’t turn on again, there is a "“code list”, with a few or tens of alternative codes that are most likely to help you getting the connection to work.
Now back to the Somfy Connection Kit and the different models of blinds, roller shutters etc. that we are trying to connect with homey.
Why not make a more general set of icons and images for the basic functions and tell users in advance (managing expectations) that the the basic needs will work and maybe also some extra features.
  • opening the product
  • closing the product
  • stop the moving of a product at some point
  • tilting or swivelling the product
Than create a evolving list (e.g. at start of this topic) together with this community and other owners of Homey in combination with their shutter/blinds.
That lists show various brandnames (Velux, Somfy, Duux etc).
Under each name the most common way (API) to pair it with Homey2023 / Homey 2019 / Bridge.
So when you have a certain device from Somfy (e.g. “Situo 1 Io Pure II”, or “Sonnenschutz Terrasse” and it turns out it can be paired with selecting “Awning / Pergola (io)” than that would be the best practice.
To avoid confusion, the API which is most suitable (in this example “Awning / Pergola (io)”, should be renamed as for example “method 1”
And for that “Method 1” you program only the basic features mentioned before.
As the dev-op, YOU know that API “Awning / Pergola (io)” matches “method 1”, and that info could be put in a seperate file for co-developers. For users that just want to pair their new shutter with Homey, clicking on “method 1” will be enough.
When a specific device like “schuifpui links” turns out to get paired by selecting "Velux interior blind (io)”, than that will be the method for that model, and could be renamed “method 2”
Now we can all send in our best practices, by pointing out:
  • which brand+productname is succesfully paired
  • with what type of Homey
  • and the working name of the several given names in the app of that brand.
You couple the succesvol API to an existing “method” or create a new one and add it to the list
of that brand.
Maybe this will be a way to tackle this problem.
I get your idea but it doesn’t fit the Homey pairing method that I’m tied into. Athom only provides the option to select a device at the start which in turn determines the driver that is created. So the pairing method is controlled by Athom.
With hindsight, and if I could start again, I would just have one device that handles all types of window covers (curtains, blinds, shutters, etc) and then just delete all the capabilities that were not support by the API for the selected device.
I have been toying with that idea for a while, but I need to maintain backward compatibility for existing users.
Ok, I get your point. Maybe it’ll work than without renaming to “method 1, 2 , etc”.
The pairing method can stay/be at Athom’s side, but the list I suggested can act as a sort of index or legend.
So anyone with a new shutter/blind etc. can find the correct brandname and subsequently easily see, the device-name he or she should select to install the correct API.
We have the advantage that we already have gone through the frustrating trial and error and found the correct device to install our new product. That may save some time for new users and for you, hence you don’t have to answer any individual request.
Just giving it a thought, because I’d like to do something in return for your help. If not usable, than it was worth the try :wink:
I appreciate your feedback as every suggestion has merit and can spark an idea that I wouldn’t normally have, so thank you for your support.
Hello, added the connection kit to my homey pro but he says no new devices. In the logs i see them but cant select as a device. How do i solve this?
Can you send the Device Log and let me know the id. I will take a look and let you know what driver to select.
Ah, I think I have already replied via the Diagnostics Log you sent.
This is a somfy problem and not homey.
Maybe you’d better ask in somfy forum…
