Solar system from APsystems
I got it working! :grinning_face: Just had to fiddle a bit with the IP address when switching from a wired connection to Wi-Fi. Somehow it then creates a different IP address and also a different MAC address (which isn’t the one shown on the ECU sticker).
Hi Steven, I just connect mine to the WiFi, which Ip adres did u use to get it working ?
Thanks and best regards Peter.
Hi Peter, the IP address would be different in every household. Look into your router for something like EMA
Look in to your router and find the IP with the namen ESP….. That is the wifi ip from the ECU.
Tip: fix this IP in your router
Had a stuck app this morning. A reset of the app solved it. Will do a diagnostic next time when stuck.
Regarding poll time, I think official is every 3 minutes?
This morning, the app also stopt working on my Homey, but restarting the app (and the ECU) didn’t help in my case…
Since yesterday’s update my power and temperature are not being displayed correctly.
After restarting the app, only the temperature is not displayed correctly.
I’m currently using the Home Assistant app, in addition to this new app.
In the Home Assistant app, I can also see the energy yield of each solar panel.
Is this something that could be implemented?
Hi Dick and Steven, I’m in eventually I’ve got it working and found the IP address inbetween all my devices I’ve got the right one now :blush: and fixed the IP address in my Modem so that it won’t change anymore.
Zie net dat de waardes 46 min geleden voor het laatst bijgewerkt zijnšŸ™
Thanks a lot for all your effort,
Best regards Peter.
Stuck today ae well
Diagnostic before resetting the app:
92d3f616-dc2a-42ed-b47b-76fb03f9463c
And after a reset
69b5d046-2f62-4096-a02b-56d6c918a3e7
by the way, HA was also stuck:
I have to make adjustments in the software to get more info from a diagnostic report. For now I can see that the inverters were offline/ didn’t send any data.
The lifetime data will come from the ECU, so that was displayed.
Since also HA didn’t report anything, it must be something with the ECU. All inverters stopping at the same time is unlikely.
That should be possible, but for now I will try to get it working without errors and crashes :anxious_face_with_sweat:
From what I’ve seen, the ECU only reports every 5 minutes. I want to find a balance between retrieving data and putting the load on the Homey
982be4f4-a9d2-40f9-9a1c-a69bfb278648
This one the HA system is actually sending data., and that was correct wrt to the APS app.
I’ve added some more logging in the code, for diagnostics and released a new version. Now I hope I’m able to see the data coming from the ECU and see why the power is zero, or in another case, extremely high
Hi Johan, if the temperature is correct, are you saying that you produced 72kW at that moment? It seems a lot, unless you have 180 solar panels.
Hi Dick, I have 12 panels and a maximum of 4000W. The information is incorrect, but it works fine after restarting the app. However, the temperature information continues to be incorrect. I also don’t see any information about the voltage.
I still have to figure out things… that’s why I changed the code so the diagnostics have more content. I only know since yesterday what the result is when you send a diagnostic report from the app. Remember this is not my work, just a hobby :grinning_face_with_smiling_eyes:
What type of inverters do you have?
Hi Dick, here an update about my system, since 12 this afternoon I deleted the ECU-R from Homey because it was still stuck and added it again, now it’s running smoothly since.
The only question I’ve got is why I see the voltage drops because it’s hardly unlikely that that happened :flushed_face:
And what is the graph Energy usage mean because it should only generate electricity not using it, or am I wrong.
Thanks again and best regards Peter.
temperature measurement is not going quite right.
