Shelly 1 Gen 4 - connection issue
Trying to automate the garage door with a Shelly unit. For a while everything went well. Got the unit wired into the opener, and used an extension cord to get some power wires to it. Little red lite on the back is on, and the Shelly mobile app successfully connected to it and I can see all configuration options.
I just can’t get it to connect to Homey. Whenever I try to add the device through the Shelly App (Zigbee connection), it gets to the screen that tells me to press the reset button 5 times to go into Zibgee mode, then 3 times to initiate connection.
Connection attempt times out with no error or information.
I’ve tried researching online and found a couple common culprits. I’ve verified the Shelly connected on my network on the 2.4Ghx band (Homey is listed as Ethernet). I also find something about Multicast on the router - but not sure how to find that or if I really should turn it off. I also read a lot about initiating a firmware update but can’t find how to start that anywhere in settings.
One things I DO see (or don’t see) is Zigbee listed in the network connection types. Should I be seeing it?
So just looking for some help getting this thing connecting into my Homey as a device. It’s got power, and it’s on my network and in the Shelly app - seems like connecting to Homey should be the simple part?
Thanks!
A post was merged into an existing topic: [APP] Shelly - Smart solutions for every home and office
