Just to Inform you: I am working on a 433 App for the ScreenLine Remote.
The remote is produced by Pellini for their blinds between glass http://pelliniscreenline.net/ and sold under different names in various countries (fe : inblindz a.o. in The Netherlands)
The ScreenLine Remote type SL2392S159: and the corresponding receiver SL1963:
The Remote has 99 channels and one Group channel (00) where all registered Receivers react.
The App is in an early alpha state, just working registering and transmitting a short Pulse signal.
Multiple short signals can be used to create the long Pulse to Raise / lower complete.
Development is at the moment done by reverse engineering.
Please contact me / send an PM with your Homey registered email if You want to test. (I just want to make sure it works before I release something public)
ToDo:
Validate working signal at multiple Remotes/ Receivers
Add Single button Up/Down
Add separate Short Signals for Tilt
Add tilt capability
Calibration (for Height and Tilt )
Please note that this is a community App and is not official from inblindz or ScreenLine®/Pellini and there will be no support from inblindz, Pellini or Pellinindustrie concerning this App.
Info regarding on-going development:
I am in contact with inblindz and the Dutch representative in The Netherlands,
I borrowed a second remote and receiver to test and found a working signal definition that also works with the first Community member that contacted me.
The first tryout is recently re-written with help from Athom as a SDK2 App using the homey-config-composer and homey-rfdriver.
Still waiting for Homey 2.0 to implement the Tilt function the native way from Homey.
I did and also had contact with the creator. There will be an update shortly. As it turns out version 0.0.5 only works when you install it on homey 1.5 so i have too wait for the update.
Hello Geurt,
Hope you are doing fine.
Since our first contact I’m happily using the Screenline remote app; 16 screens in total. With the 2 most recent Screenlines with Li-ion battery and build-in RF receiver I’m experiencing some problems. The Pellini remote functions ok with the 2 screens and I was able to learn the remote signals to Homey however when I want to operate the screens through Homey the 2 screens are not responding. When the screens are operated through the connect wired controls and shortly after through Homey it does work; seems the battery/remote is perhaps in a sleep/standby mode.
Are you aware of this? Can I do something myself to solve this or can I somehow support you on this?
Or?
Looking forward to your response.
Stay healthy.
Rgds, Jos
