My homey functions “flawlessly” up until the last week (june 2021) I have a "Early 2016""with version 7.0.0.
I haven’t changed anything (added apps of change in z-wave of zigbee components) special in the last few months.
Since this week i have noticed several Red Led-ring alerts with a frozen Homey. Sometimes the alert disappeares spontaneously sometimes I have restarted the Homey (dis- and reconnected the power).
When i check the memory: it is not even half engaged.
What causes the problem and what can I do to remedy it?
Are you using the original Athom power supply that came with Homey? If so, try replacing it with something better (5V, at least 2.1A, preferably from a good brand).
Yes. I am using the original powersupply. I will try another.
It is not that easy to find a powerfull Quality powersupply with a mini usb connector.
Just use a USB-A to mini-USB cable, you can plug those into any regular USB charger. If you happen to have an old iPad charger, those are great.
Did changing the adapter resolve the red ring issue?
Yes, since I changed adapter I haven’t noticed a crash.
Thanks for the sdvice
VanGilles thanks for your advice. It has been 4 weeks now and no crashes have occurred!
