Ring image grabber problem
I am also availeble to test with the battery Function.
@denniedegroot I see there has been an update to the master branch 5 days ago. I just noticed i’ve got version 2.1.1 installed of the Ring.com app which is a beta. I haven’t installed this through CLI, so did it get removed from the apps site?
And is the version in the master branch with the batteryfix the latest version? Which seems to be 2.0.5? I’m not entirely sure anymore.
2.0.5 is the latest version. The 2.1.1 beta is indeed removed because the features don’t work anymore.
However if you have the 2.1.1 beta installed it will probably not upgrade to 2.0.5 because its a lower version.
Right, so the advise is to remove and install 2.0.5?
Could you have a look at Aanmelden Ring PRO Homey, because I don’t what that to happen :wink:
Can’t you just install the non-beta through the appstore? I think it will overwrite your current beta-app without removing the settings (and authorisation).
@Fire69 You are correct. That’s what I’ve did and it’s worked fine.
Just waiting on the image grab functionality to be added
Installed sucessfully the latest version of the app.
Hopefully soon more functions. I would like to snooze by a flow.
Super work! Can I install it from github?
No, this version is not on Github
Wow! That is indeed great! I’d love to install this too.
TIA
Why not put it on github? Easier for everyone.
Because I just made changes to the version maintained by @denniedegroot. If he is fine with it he can receive a pull request and can merge it.
Can you share how it should work? (tried removing and readding the Video Doorbel too)
I’ve got the following (bad DU -> EN translated):
Flow 1:
If: motion sensor is activated
Then: get current snapshot
Flow 2:
If: Snapshot is collected
Then: ?? Cannot seem to do anything with it… or am i just mistaking?
Edit: How rude; thanks for picking this up! And really big thanks for setting the beta version number a bit higher than 2.1.1 :wink: no need to remove my authorization.
Right, let me know if you have a new version… i’ll test right away.
@denniedegroot made a new beta version with image grabber fix so please ignore my posts about my version.
You are late… There is already an update which fixes the image grabber on the beta branch
Only better if he fixed it :slight_smile:
It’s fixed and it works!! Thank you everybody who’s involved in the realization.
I installed the beta and I’ve found the card to retrieve a snapshot. How to I send this to my phone now?
The ‘send a push image’ doesn’t show the Ring. Do I need to send it through Telegram/Pushbullet/…?
It is the right one you are using. You should use the tag “image” as what is going to be send to your phone.
Like this:
