Is it possible to restore/add a Matter device (from Philips Hue bridge) which was accidentally deleted in Homey? I can’t use the same pair code again, so what to do?
Had the same issue, did not find a solution yet
Isn’t this how it works? Worth a shot:
Don’t try to add the Matter device to Homey, but (remove and) re-add it to the Hue hub:
I just had this issue and removing and then adding it again to the Hue hub worked
