Reolink doorbell onvif connected
Hello!
I’ve been browsing the forum a lot and saw that others had similar problems, but unfortunately I can’t figure out what the problem might be.
The subject is Reolink D340p door phone and P320 cameras.
I connected them successfully, and the IP address and password are correct. RTSP ONVIF is enabled in the Reolink app.
Motion triggers the flow, but there is no live image!
Only an ECONNREFUSED message.
What am I missing?
Thank you for reading.
Tamás
Above the snapshot image, there’s a dropdown menu to select the live stream.
(NOT available for Pro 2016-2019 models)
This most possibly means the cam has no http server (enabled) in order to access the saved snapshot;
This URL should work in a browser:
If not: URL is possibly incorrect, or the cam has no (enabled) webserser.
To illustrate: my doorbell cam has an onboard webserver, my E1 Pro has not!
The latter throws in a ECONNREFUSED error ( = connection refused = nothing there)
It’s visible in the settings:
Doorbell:
E1:
Yes, it works! :smiley:
Http and Https were not enabled…
I am grateful to you! :blush:
Thank you very much for your help!!!
