No Camera feed when adding Camera's via Reolink NVR in Homey
Hi All,
I have 2 X Reolink Duo 2 POE Camera’s and Reolink RLN8-410 NVR
Originally, I just had the 2 X camera’s configured in Homey using ONVIF Camera app.
The camera’s were identified by Homey and I could see the live feeds from each, no issues.
Yesterday i introduced the NVR (connecting the camera’s into the NVR, not the switch)
I deleted the 2 individual camera’s from Homey (under devices) and when adding the NVR I again used ONVIF, I added the IP address of the NVR and then i supplied the ONVIF Server port as 8000. On the NVR settings i have enabled RTSP (server Port 554)
which then pops up an option to enable ONVIF, which is enabled (server port 8000).
Ive left RTMP\HTTP\HTTPS as disabled
Homey detected both camera’s as channel 1 and 2. Now when I attempt to go open each of the camera’s under devices for a live feed in Homey I receive an error message orange box “! ECONNREFUSED”.
Any ideas what i should be doing to rectify this?
Any guidance would be appreciated.
Regards,
mcos0544
You will need to enable the HTTP protocol as snapshots come via that. The ONVIF app doesn’t use the RTSP protocol.
