What is the correct way to activate my withings sleep analyzers after a firmware update of homey !?
Every time a firmware update is installed my sleep analyzers loose connetion.
Recover maintenence or restart the withings app doesn’t solve the problem.
I have to uninstall the app and install it again, also reconnect the sleep analyzers and fix the flows to get it working again
what works for me (HP Early 2023):
- restart the withings App.After that:
- re-pair the withings devices. (i have 2 for 2 users).
re-pairing the first device prompts first for a login in the Withings-server.
Next I have to select a user,
Subsequently I get a Homey-screen: scroll down and don’t forget to select “Gebruik deze app/use this app”. On smaller screens this button may not be visible without scrolling. (it took me a while to find it).
then you get the screen “you can now close this window”.
I repeat these steps for mmy second user.
I hope it will work for you too.
koind regards,
Paul
Thanx Paul I’ll try it with the next update your reply is very much appreciated!
Hi Paul today was a new fiemware update and I was very excited to try but without result (I have 3 analyzers). The only option left was te remove the app and install the analyzers again. Thanks for your input.
I am sorry to hear that. Did you also restart the app? I am not sure if you first have to restart the app before repairing the users or the other way around. In my case it is a little bit trial and error.
Hope this issue will be solved in the near future.
Kind regards,
Paul
Jeroen, I recently run into the same trouble that I could not reconnect my Withings devices after an update.
But I noticed that I was successful when I follow the procedure rather slowly. So between each step I include a one-second wait. That helped.
Thought, I should let you know.
Regards,
Paul
Thank you for this hint. That did the trick for me and my wife
