I installed a qubino ZMNHDD1 flush dimmer, and in the homey there is no report of power usage / energy.
I logged in to the developer.athom.com area and i see the qubino sending z-wave messages to homey in the logging.
[2019-02-27T15:20:23.393Z] Node[2]: Received application command for COMMAND_CLASS_METER, data: 0x02215400004483012d0000451a
[2019-02-27T15:20:23.395Z] Node[2]: [COMMAND_CLASS_METER] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[33]},“Properties1”:{“Scale bit 2”:false,“Meter Type”:“Electric meter”,“Rate Type”:“Import”,“Meter Type (Parsed)”:{“value”:“Electric meter”},“Rate Type (Parsed)”:{“value”:“Import”}},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[84]},“Properties2”:{“Size”:4,“Scale bits 10”:2,“Precision”:2},“Meter Value”:{“type”:“Buffer”,“data”:[0,0,68,131]},“Delta Time (Raw)”:{“type”:“Buffer”,“data”:[1,45]},“Delta Time”:301,“Previous Meter Value”:{“type”:“Buffer”,“data”:[0,0,69]},“Scale 2 (Raw)”:{“type”:“Buffer”,“data”:[26]},“Scale 2”:26,“Meter Value (Parsed)”:175.39}
[2019-02-27T15:20:24.498Z] Node[2]: Received application command for COMMAND_CLASS_METER, data: 0x02a1425c82012d5c9d
[2019-02-27T15:20:24.499Z] Node[2]: [COMMAND_CLASS_METER] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[161]},“Properties1”:{“Scale bit 2”:true,“Meter Type”:“Electric meter”,“Rate Type”:“Import”,“Meter Type (Parsed)”:{“value”:“Electric meter”},“Rate Type (Parsed)”:{“value”:“Import”}},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[66]},“Properties2”:{“Size”:2,“Scale bits 10”:0,“Precision”:2},“Meter Value”:{“type”:“Buffer”,“data”:[92,130]},“Delta Time (Raw)”:{“type”:“Buffer”,“data”:[1,45]},“Delta Time”:301,“Previous Meter Value”:{“type”:“Buffer”,“data”:[92]},“Scale 2 (Raw)”:{“type”:“Buffer”,“data”:[157]},“Scale 2”:157,“Meter Value (Parsed)”:236.82}
[2019-02-27T15:20:25.392Z] Node[2]: Received application command for COMMAND_CLASS_METER, data: 0x02a14a004f012d0050
[2019-02-27T15:20:25.393Z] Node[2]: [COMMAND_CLASS_METER] {“Properties1 (Raw)”:{“type”:“Buffer”,“data”:[161]},“Properties1”:{“Scale bit 2”:true,“Meter Type”:“Electric meter”,“Rate Type”:“Import”,“Meter Type (Parsed)”:{“value”:“Electric meter”},“Rate Type (Parsed)”:{“value”:“Import”}},“Properties2 (Raw)”:{“type”:“Buffer”,“data”:[74]},“Properties2”:{“Size”:2,“Scale bits 10”:1,“Precision”:2},“Meter Value”:{“type”:“Buffer”,“data”:[0,79]},“Delta Time (Raw)”:{“type”:“Buffer”,“data”:[1,45]},“Delta Time”:301,“Previous Meter Value”:{“type”:“Buffer”,“data”:[0]},“Scale 2 (Raw)”:{“type”:“Buffer”,“data”:[80]},“Scale 2”:80,“Meter Value (Parsed)”:0.79}
Is this a known bug in the qubino app or am i dooing something wrong ?
With kind regards,
Martin
