Problem with Homey Web App
Hello!
I have problems with the Homey web app. When I’m going to make a flow, I just get a blank box. There are no suggestions on the right to choose from. Same thing happens on both Safari and Chrome. Anyone know a solution to this problem?
Have you tried incognito and or removed all cookies?
Do you have a pi-hole or other specific network config with filtering?
Removed or disabled all browser extensions?
Open the developer tools of your browser (not the developer tools of Homey) and check if there are any errors appearing in Console.
Hello!
I have removed all cookies without success and can not see any error in console. Now I even can’t see my devices.
Refresh the page.
Click on your Avatar to see if the right Homey is chosen.
Hi @Daniel_Ideborg did you manage to find a solution for this? Im having the same issue with the Web App being empty. No devices or flows are visible.
Update: When looking in the browser console I could see that homey.homeylocal.com could not be accessed. A quick look in NextDNS showed that it was blocked as part of the “DNS bypass protection” option. Whitelisted the domain and now it works :smiley:
Is there currently know issues for Homey Web app as all my flows are missing and at time I can get devices page to load fine. No issues on Phone app.
I have already tired 3 different browsers and cleared my cache etc. still same issue
Just keep getting Network request failed error
Not that I know, also nothing here: https://status.homey.app/
Homey or Homey Pro ?
No Problems here…
Have you tried a different network (Hotspot?)
Homey Pro 2023
It was working on and off earlier today but again tonight same issues.
Have created a support ticket so will wait and see what they come up with .
I’m on Homey Pro 2016 but my flows are no longer visible - even though I can see they run in the notifications. Did you solve your problem?
Default question is: what have tou tried already?
I have tried:
  • Different browsers
  • Different devices - phone and laptop
  • I cannot use the iOS app as it won’t work with the version of the firmware I’m running on Homey
  • Logged in and out
  • Restarted Homey
  • (I won’t upgrade Homey firmware as many of the devices I use do not work on the later versions - LightwaveRF 1 for example)
  • I suspect that the updates to standard flow/advanced flow models mean that some of what I have is now incompatible, but, it’s peculiar to me that they still work I just cannot see them to modify them
And wouldn’t you think that your issue with the web app is caused by the same?
What Homey Firmware are you running?
and what is not working anymore since what Firmware ?
Indeed I would and posting on here is to see if others have experienced the same to determine if that is the cause - i.e if it’s really unfixable. That said I could understand if flows didn’t work anymore but they do, there are just not visible or editable. Nothing has changed on my setup for 4 years
Running 4.20 on original Homey. It’s been running this for many years, no upgrades, no problems. The iOS Homey App hasn’t supported this version for a few years now too so I am constrained to the web. The LightwaveRF app/devices are incompatible with newer Homey versions and they are my primary devices which is why I won’t upgrade.
Why wouldn’t they still work? Nothing has changed on your Homey, it’s just that the apps (web/mobile) that are showing your Homey’s data have since been updated and don’t work anymore with the responses that they get from your Homey.
In other words: it’s a display issue.
