Bought 2 pcs of this radar sensor because its ceiling mounting and 230v power supply suits me.
It says it is working with tuya app, but so far no succes. It is added as a generic Zigbee device.
I tried the tuya experimental app with the radar sensor.
Any other sugestions to try?
This is the sensor:
https://a.aliexpress.com/_Eu7d8hz
Maybe you wanted to buy the wifi version?
A presence sensor on zigbee isn’t a good idea btw. It can be very chatty, and clog your zigbee mesh.
If uncle Ali says it’s supported by the Tuya app, you’re wrong I’m afraid;
They don’t mean the Homey app, they mean the mobile Tuya Smart app, and you’ll need a Tuya zigbee hub.
From the link you posted:
And, please read this topic about the big issue with Tuya zigbee devices and Homey:
For both Aqara and TuYa the same applies: you have to have the exact correct model, otherwise it won’t be supported.
As @Peter_Kawa already pointed out, with TuYa you will never know if the device will work with Homey until you have it in your hands. Even if someone else has the same device, there’s not guarantee it will be supported.
What you can try for now: install the Tuya Zigbee test version of this Homey app, it supports many new devices and devicetypes.
If it still doesn’t work:
Request for support, first read the first post here ; this can take a while
return the sensor, and first check which sensors are supported before the purchase
buy a Tuya zigbee hub (€10‐15), and connect it with the Tuya Cloud app to Homey, and/or request for support here , the new Tuya app by Athom
Excellent, thanks for the decent reply! The test version of the app did not bring a solution. I will try to find a better sensor…
Aqara FP2 works, but it’s quite expensive. But is has multiple independent zones
Project started as a way to include the Aqara FP2-sensor via Homekit into Homey.
App is now more generic, many services and capabilities are supported. If you encounter problems, please PM me a short note and a copy of the log where you add the device.
Generic procedure to add a device.
Add your Homekit capable device to the app that came with the device and configure it.
If added with iOS device, remove the device from the iOS Home app, a device only can have one controller.
Most of …
I was wondering if anyone has this sensor that Rob_Scherpenzeel also has working in the Homey app? How did you do that?
We also have this Wenzhou sensor and would like to add it to the Homey app.
