I have recently upgraded my Homey to v2. With version 1.5 Hue lights worked very reliable but now with version 2 i have many problems controlling the lights with HomeyScript.
When switching lights on or off some lights are not turned on/off. Sometimes i get an exception, sometimes not. When i get an exception it is like this: (but not always exactly the same)
Philips Hue: 201, parameter, ct, is not modifiable. Device is set to off.: Philips Hue: 201, parameter, ct, is not modifiable. Device is set to off.
at /node_modules/athom-api/dist/index.js:1:1049744
at
at process._tickCallback (internal/process/next_tick.js:189:7)
name: ‘Philips Hue: 201, parameter, ct, is not modifiable. Device is set to off.’,
code: 500,
cause:
t {
__athom_api_type: ‘HomeyAPI.ManagerDevices.Error’,
code: 500,
error: ‘Philips Hue: 201, parameter, ct, is not modifiable. Device is set to off.’,
error_description: ‘Philips Hue: 201, parameter, ct, is not modifiable. Device is set to off.’,
‘$stack’: undefined } }
Strange thing is, i didn’t send a parameter CT. I don’t even know what it is. The command i send was
Homey.devices.setCapabilityValue({deviceId: [id], capabilityId: ‘onoff’, value: ‘false’})
Again, with Homey v1 i have n’t noticed these errors. Does anyone have the same issues? I use the lights with the bridge
