Hello i’m new to homey, just got my homey pro and I’m very excided.
For about 6 years i’ve been using a zipato zipabox, but it died on me and I wanted to try something else.
I started adding all my z-wave devices, but i’m not getting ANY z-wave device included ( paired) with homey. For example I tried 2 fibaro powerplugs, fibaro smoke detector, and greenwave powerplug.
And yes I was close enough to homey, I was holding it next to the devices.
I added and removed the apps multiple times, also did a reset of the z-wave. and restarted homey.
I turned on the z-wave logging to check what is going on and I found that It just times out in the process.
[2019-09-06T18:59:55.238Z] Command[3] start: addNode
[2019-09-06T18:59:55.272Z] Command[3] status: addNode, status: ADD_NODE_STATUS_LEARN_READY
[2019-09-06T19:00:25.323Z] Command[3] status: addNode, status: ADD_NODE_STATUS_DONE
[2019-09-06T19:00:25.324Z] ProcessAddNode[2]: Error: timeout
[2019-09-06T19:00:25.334Z] Command[3] end: addNode
[2019-09-06T19:00:34.615Z] Command[4] start: addNodeAbort
[2019-09-06T19:00:34.617Z] Command[4] end: addNodeAbort
[2019-09-06T19:00:39.886Z] Command[5] start: addNode
[2019-09-06T19:00:39.902Z] Command[5] status: addNode, status: ADD_NODE_STATUS_LEARN_READY
[2019-09-06T19:01:09.958Z] Command[5] status: addNode, status: ADD_NODE_STATUS_DONE
[2019-09-06T19:01:09.958Z] ProcessAddNode[3]: Error: timeout
[2019-09-06T19:01:09.963Z] Command[5] end: addNode
[2019-09-06T19:01:17.521Z] Command[6] start: addNodeAbort
[2019-09-06T19:01:17.523Z] Command[6] end: addNodeAbort
[2019-09-06T19:01:37.614Z] Command[7] start: addNode
[2019-09-06T19:01:37.631Z] Command[7] status: addNode, status: ADD_NODE_STATUS_LEARN_READY
[2019-09-06T19:02:07.686Z] Command[7] status: addNode, status: ADD_NODE_STATUS_DONE
[2019-09-06T19:02:07.686Z] ProcessAddNode[4]: Error: timeout
[2019-09-06T19:02:07.690Z] Command[7] end: addNode
[2019-09-06T19:02:17.055Z] Command[8] start: addNodeAbort
[2019-09-06T19:02:17.057Z] Command[8] end: addNodeAbort
[2019-09-06T19:02:23.336Z] Command[9] start: addNode
[2019-09-06T19:02:23.351Z] Command[9] status: addNode, status: ADD_NODE_STATUS_LEARN_READY
[2019-09-06T19:02:53.407Z] Command[9] status: addNode, status: ADD_NODE_STATUS_DONE
[2019-09-06T19:02:53.407Z] ProcessAddNode[5]: Error: timeout
[2019-09-06T19:02:53.411Z] Command[9] end: addNode
i’m not sure what to do next, Is the z-wave bad in my homey ?
Can anyone help me ? Otherwise I will have to send it back to the store.
