Noob question: why does "solar" stay empty
Here is my Energy tab on my phone:
It does not show a value for solar energy generated by my PV panels.
But I do have an inverter and it is generating energy:
I checked setting, but have no idea how to include the Solis generation in the Energy settings.
What am I missing here?
Thanks!
Does your solar device provide a meter_power capability? This is needed to get the kWh data.
Thanks!
Seems it doesn’t:
I have contacted the developer @Kim_Kokholm via his App page.
If the inverter does not provide a power meter, you can use the PowerByTheHour app instead.
I have PBTH installed and it is already linked to the PV Inverter. How do I link PBTH to Solar in the Energy tab?
It must have “solarpanel” as device class. Don’t know if PBTH allows to change device class.
New version is out for testing.
BTW! Do you also get suggestion in the “Power ups” section regarding “energy dongle” and “where to buy solarpanels” EVEN when you have Solar-panels and a Energy Dongle already installed :slight_smile:
Thanks @Kim_Kokholm
Installed the new version
Removed the device
Re added the inverter
Device works
Unfortunately, not reporting in Energy:
Yes I do!
Perhaps a repost (lost the other one)
In the Energy tab I do see a yellow animation showing power from the PV panels into the house.
It doesn’t show in the value a bit higher in the Energy tab. Perhaps tomorrow once net power is registered.
Thanks for the swift response!
I have no solution for this. I’ve tried switching from a borrowed account and my own solar (not solis) and its kinda bugged for me.
Maybe it will settle…
Thanks for the effort!
Afaik the daily value doesn’t show right away, but starts showing the next day. It has to calc a daily use value first.
Something like that. I’ve read it somewhere at the forum
Patience is not one of my strengths :sweat_smile:
The graph shows PV production, but I bet still some calculation is happening under the hood.
Let’s see what happens the next weeks.
I used to have a similar issue with my solars, but probably for other reasons than you.
I resolved it by doing the following:
  1. Create a Virtual device with device class Solar panel (I named it Solceller)
  2. Added a Power by the Hour app for the virtual device called Solceller.
  3. Created a flow when PV input changes from my original solar app (Growatt + Modbus TCP), it pushes currentsPV W to measure_power and todays kWh use from PBTH to meter_power.
This workaround has worked well for me, hope it can be useful for you as well.
Interesting!
Will try that tomorrow!
Tried your suggestion @Hass
Added the VD (ZD - AVD 13):
and set the capability as “Solar panel”.
Next step was adding the PBTH device, that was not a problem. However, it does not show the created VD to be added as source:
What am I doing wrong here?
Ah sorry, the app I use is Virtual devices.
You can do the following after installing the app:
  1. Create a Device.
  2. Add name and image.
  3. Select device class as Solar Panel.
  4. Add both Power meter and Power.
  5. Add a PBTH device with Energy summary for the device you just created.
  6. Change the settings for the PBTH device to have source as Watt.
  7. Create a flow similar to my last post to update the Power and Meter power values and you should be ready to go.
Thank you for the extra information! Really useful!
I now see a value in the Energy tab (albeit still zero).
Guess it will update soon.
