I can’t get my Nimly Touch Pro to take the command Auto Relock Disabled,
This is the flow, that should disable auto relock and keep the door open.
But after running the “Set auto relock to No” the door still auto relocks after 7 sec.
I can see in Homey’s Nimly Pro Touch setting that the flow actually toggles the device tag Auto Relock to disabled.
So now when AutoRelock seems to be disabled, if I just run a Unlock, door should keep open.
I also contacted the Nimly Support and got this answer:
“ As the lock is a battery device, it can normally not be reached by Homey for these settings, but only when it is active, for example when being unlocked. This is why we keep trying to apply this setting in the background, but it can sometimes fail all together. Best is to configure the auto relock once. “
And later: “There is a difference between a command and a configuration update: the first is always accepted, the second unfortunately is not. We keep trying to apply the configuration update, but unfortunately there is currently no way to know when the lock does accept the update. Our recommendation would be to create the auto relock yourself in flows, as that is the most flexible option, and to use the auto relock option of the lock only in cases where you always want to have the auto relock configured.”
I did exactly copy your flow, and i got the same behaviour as you.
Then i tried my own flow,and i then also got the same behaviour (it worked before).
Then i did take out one battery and then reinserted it. And my flow again works just fine. Nimly (or Homey?) seems to hold some temp or whatever leftover that has been a problem for me regarding Nimly.
If the battery thing doesnt work on first try, exit homey app, and redo the battery thing, and enter Homey and run the flow.
My Nimly Pro works perfectly! When you reprogram the lock (activate autorelock) add a bit time before you give a new command! After the “set autorelock…” I have added a time-delay of 10secs. this solved the problem!
Have you got it to work the other way?
I have a flow that unlocks my Pro Touch when i arrive and sets the autolock to “no”.
It says no under settings in Homey but still they locks within 2s.
If I unlock them manually in Homey they still locks within 2s.
I also have these problems. This is really annoying. Did anyone manage to solve this? Normally after a restart of the homey app and the lock (by removing a battery) it works. But we can not do that everytime
I have set up a flow that restarts the app every night and now it works most of the time.
Not perfect and shouldn´t be needed but haven´t found another solution.
