New Sonos registration fails
Hello, On a Homey Pro 2023, it fails to re-login my Sonos devices after a Sonos reset. The message below appears. Anyone have an idea what the cause could be?
"Cannot read properties of undefined (reading ‘find’)
Groet,
Rob
This is a bug in the app. You should contact the developer.
I’m having trouble installing my existing Sonos system. After entering my Sonos credentials and authorizing Homey to control my Sonos system, I get the following error message: “cannot read properties of undefined (find)”. After a search on the forums, I saw that a user had encountered a problem and had reset the Sonos equipment. I deleted and factory reset all my speakers and installed them one by one. The error message is still there.
Have you heard back from the developers?
No, unfortunately nothing heard yet. Also here all speakers back to factory settings and reinstalled. Without success. Same error message. I think it is useful if you also report it to Athom.
I’m getting the error ERROR_AUTHORIZATION_FAILED when I try to play a favorite. I already created a ticket a few weeks ago (Nov 4, 2024, 07:04) but until now no solution. I still can set volume, but I’m unable to start/pause the music as well.
I have the same issue
Same issue here…
same problem also
Is it about registering the Sonos app with Google??
There are problems across Europe.
First I had problems with the homey app on Google - now also on Sonos.
The problem could also be due to Google.
But homey is OK again now
No, it’s not a Google problem. I’m just not able to play playlists and favorites with the Sonos Homey app. Still getting errors ERROR_AUTHORIZATION_FAILED or ERROR_RESOURCE_GONE.
Hai, Do you have any idea how to get a response from the developer, reported 2 weeks ago, no response whatsoever… Greetz, Rob
The developer is too busy with dashboards and other Shiny New Things, I suppose.
I’ve created a new ticket. Previous ticket was closed without solution.
Hier opgelost met de bèta 6.6.1 app van Sonos.
Also downloaded the beta app but still not working. Was all functioning well but suddenly stoped one by one
Moin,
I’ve already reset and reinstalled my entire system.
I have a Beam and a One.
I only install the Google Assistant on the One.
If I want to change the volume on the One using a voice command, the volume on the Beam is changed.
At times I also had two different systems with the same name.
It’s all very strange. :thinking:
(Sonos-Firmware Version: 16.5 (Build 82259204))
The Homey Sonos app doesn’t seem to work properly either.
I can’t control play, stop, pause or anything similar using Flow.
