Unable to group Sonos speakers through Homey
Hello!
I’ve been trying to set up a flow to play a playlist on more than one of my Sonos speakers at once, but when I try to use the “Join the group of …” card no devices show up in the list and searching for them also results in nothing. This is using the web app.
If I use iOS app I am able to find the devices fine using the “Join the group of …” card, but nothing happens when I trigger the flow. The error message is “Cannot read property ‘id’ of undefined”.
I’ve tried removing the Sonos app from Homey and reinstalling it, but it doesn’t help.
Has anyone experienced this? Found a fix?
Playing a playlist from an individual speaker works fine.
Thanks in advance!
No problem here, I used the URL: https://my.homey.app/flows
After running the flow the speaker is added to the group.
Huh! That is weird, I’m doing the exact same thing as you. Problem is that my list of devices is empty, even though I have five of them added to my Homey.
Please try to click on the blue dots first (or anywhere outside the add card).
So this is what happens when I do that:
I have five devices added, but they don’t show up. Weird.
What happens if you restart the Sonos app.
Click a 2nd time on the blue circle with the 3 dots.
Unfortunately, that does nothing. :face_with_raised_eyebrow:
I use Firefox or Chrome and I have to click 2 times on the blue circle.
Click inside the “Pick a device” bar, or enter the first character of a Sonos device in there.
(I think :grimacing: )
Thanks for your replies everyone! Unfortunately none of your suggestions did the trick. I’ve sent through a support request to Athom for them to look at. Hopefully they can help me. Thanks again for taking your time with this! Cheers!
Please update me when you have some idea. Im strugling with exactly same thing. But im able to actually add speakers on flow
But true web app, i dont find speakers
Seems like we’re having the exact same issue. Will let you know what Athom replies to me as soon as I hear back from them.
Hey again! Just heard back from Athom. They were able to replicate the issue and are looking to fix it with the next release of the Homey app. make sure you update when they release it. :relaxed: Have a nice weekend!
Did this ever get fixed. I have this issue now with my Homey Pro2023
In trying to create an advanced flow to group one player with another, it does not show me the correct list. I have 4 Sonos players (Kitchen Connect, Garage Connect, Move, Living room playbar). When I go to group my Move in with what my Kitchen Connect is playing, it does not show the Kitchen Connect as a valid player in the drop down. BUT it does include the Move itself. See Pic
In another permutation I did manage to achieve the reverse - it only showed the Kitchen and Garage Connect’s, but not the Move or Playbar.
CLEARLY A BUG - there is no valid logic to this.
My speakers come up when I use “join the group of”, but it just doesn’t work. I want to press an Ikea bilresa button and then group all speakers and set them to a specific volume. insetead of the fiddly going into the sonos app every time I want to listen to music.
It would be nice if the sonos app recognized the sonos app groups. It would of course be nice if the Spotify app could recognize the sonos groups, but that seems a bit too much to ask.
Im fed up with sonos, but too heavily invested in units to switch to any other alternativ
Gemini suggesten adding “leave the group” first and then delays to not overload sonos, but this has not worked.
I assume you are using the official (cloud based) Sonos app by Athom. You might want to try if grouping works with the community Sonos app for Homey. It has the added benefit that it provides more functionality and works locally.
Unfortunatly the community Sonos app seems to have the same issue. No devices appear.
How have your speakers been set up in Sonos’ own mobile app, when you open the Settings menu and check the Your system section?
In my case I see the same Sonos-systems (sets of speakers in a room) over there as are included in the grouping flowcard in Homey:
