Is it possible to create a flow for a Nest Thermostat to turn on a device “when fan turns on” and off again “when fan turns off”? I am researching scent diffusers and only want them to dispense when the fan in my HVAC system is running. Thank you
Hi Peter, Thank you for your response. The problem is, the modes do not include “fan”. Normally, the temperature setting and mode would stay consistent. In A/C mode, the compressor would kick in and the fan would then turn on until the desired temperature is reached and turn off again. The diffuser would continue to run without the fan dispersing the scent. Therefore wasting the scent oil. I currently use a diffuser that is connected to a HVAC air switch connected to a forced air duct which turns the diffuser on and off as needed. The problem is, that is a very expensive diffuser and I want to install a much smaller and less expensive unit that does not have that capability in my vacation home. The geek in me of course thinks this should be an easy option but of course, I’ve already spent more time trying to figure it out than it will ever be worth…
Hi Bill ,
Wondering if you found a solution. I have the same setup with my diffuser and I’m looking for a solution. Thanks.
Hi Peter,
I apologize, I just saw your reply now. Thank you for your help.
Hi Rusty, I have not. Nor have I found solutions for a myriad of other issues. As hard as I try to love Homey, unfortunately, I have found very little consistent success. Coming from Vera and Smartthings, the development of the platform and the learning curve involved feels like the clock has been turned back 20 years. Technology should be evolving and not make everything more difficult than it was so many years ago. I’m still struggling through it because it was a large investment. Hoping it will catch up. Good luck
Thanks Bill for the reply. I feel the same way.
No problem, Bill, but, thank you.
