I have forked GitHub - Signalare/com.se.wiserapp: Schneider Electric Wiser to try to add the Shutter puck.
I have got the blind running but now I need to calibrate it so it can be set in a specific %.
In the wiser app you add the number of seconds it will run when you do this.
These are the attributes after interviewing the Zigbee device
"windowCovering": {
"attributes": [
"acl": [
"readable",
"reportable"
"id": 0,
"name": "windowCoveringType",
"value": "tiltBlindLiftAndTilt",
"reportingConfiguration": {
"status": "NOT_FOUND",
"direction": "reported"
"acl": [
"readable",
"reportable"
"id": 7,
"name": "configStatus",
"value": {
"type": "Buffer",
"data": [
3
"acl": [
"readable",
"reportable"
"id": 8,
"name": "currentPositionLiftPercentage",
"value": 100,
"direction": "reported",
"attributeDataType": 32,
"minInterval": 0,
"maxInterval": 60000,
"minChange": 1,
"status": "SUCCESS"
"acl": [
"readable",
"reportable"
"id": 9,
"name": "currentPositionTiltPercentage",
"value": 100,
"minInterval": 5,
"maxInterval": 600,
"minChange": 1,
"status": "SUCCESS"
"acl": [
"readable",
"writable",
"reportable"
"id": 23,
"acl": [
"readable",
"reportable"
"id": 65533,
"name": "clusterRevision",
"value": 2,
This is the code right now which I have tried that doesn’t really work for setting the correct position but does make it move:
// Register windowcoverings set capability and configure attribute reporting
this.registerCapability('windowcoverings_set', CLUSTER.WINDOW_COVERING, {
setParser(setValue) {
// Apply calibration factor to convert setValue to the appropriate range
const calibratedValue = (0.87 / setValue);
return calibratedValue;
It is the attribute currentPositionLiftPercentage that needs to be set correct.
If I do it manually it shows 13 when it is maximum open and 0 when closed. When the code runs it ends up att 255 which seems to be max for the driver.
Any one that has an idea on how to accomplish that?
