I’m using a Qubino Flush Shutter DC 24V (ZMNOHD1) to operate my motorised blinds. I’ve managed to get the meachanism to work but the Flush Shutter thinks it’s at its lowest end point about halfway down. I’ve tried changing “Up/down moving time of motor” and “Limit switch power consumption”, but nothing have worked so far. What am I doing wrong, a little help please?
I’m sorry but I fail to see where in the manual I can read about calibrating end points i.e. when the blinds are fully down/up. The manual only seems to describe how to add and remove the device from a Z-wave network.
The activation of the calibration (set parameter 78) can (mostly) be done in the Advanced-settings of the device.
(Select “devices”, select your “QubinoFlushShutter”, select “CogWheel” in the upper right corner, then select “Advanced settings” )
