I have 3 Namron Zigbee Edge thermostats set up via Homey Pro. Every time I restart Homey Pro, these 3 disconnect. The only solution I’ve found that helps is to select shut down on the switch itself. Restarting via the switch reconnects them. Does anyone else have this problem? There is no quick fix for this in the menu. You can select Try to repair in the device itself in Homey Pro, but then you also have to physically go to the thermostat and pair it again. This doesn’t work either - the only thing that works is disconnecting and reconnecting.
