My zigbee is not working
That’s normal for Zigbee — you can connect up to around 50 devices reliably. You can add more, but in my experience, problems start to occur when I go beyond that. At first, it might work for a few days, or even weeks, but eventually devices start disconnecting.
Now, I keep the limit at 50 devices, and everything works fine. Also, make sure to connect your Zigbee routers first, then add the end devices — that makes a big difference.
If you need to go beyond 50 devices, consider using Z-Wave as well, or setting up a Homey Pro on each floor. That way, you can have up to 50 Zigbee devices per floor, and it stays much more stable.
I assume you are making this statement in connection with using an older Homey Pro model?
I have no issues in controlling 65+ Zigbee devices (plus several non-Zigbee devices) on a Homey Pro 2023.
no i have like 2023 homey pro i can not get it more then 50 device i don`t know why i already try it but yeah
after like 1 week or more then starting disconnecting it en i already ask homey for that but no help that is why i stoppen en then i buy a home assistant for the support i have more then 83 device on me 2 homey bridge en one homey pro 2023 but now i have 43 device only to make sure i have always contact with the device
I don’t understand what you write, it seems about zigbee trouble, but here’s some very useful zigbee info:
