My Homey restarts on its own
Hello everyone,
I have a problem with my Homey, it restarts on its own.
Do you have any avenues to explore?
Thanks
First of all replace the power unit with a decent, well-known brand version, 5V and 2A or higher. Replace the cable as well (just in case).
(The original power unit is known for outputting less than 5V over time)
thank you @Peter_Kawa I will test this, is there a “clean” way to turn off homey?
YW.
No.
Oddly enough you can soft-restart it, but to switch it off, cutting the power is the only way…
good evening
I changed my diet but it didn’t change anything.
what else can i do?
I thinks it’s best to inform Athom, if you didn’t already.
You can create a diagnostics report up front (gets explained when you follow the link), so maybe the team can discover anything odd.
One thing you can do after that, perform a so-called Full Software Download
@Peter_Kawa
Thank you for your, I will test this.
