My homey have the 2 last night gone into a error mode, and does not react to anything…
All devices and flows are marked with a error …
When I restart homeypro the everything works again…
You can try to unplug the power for some time and start it up again, or maybe you have a problem with the power adapter. Try a different one with at least 2 Amps.
I Works fine after a restart… But it should not be needed with 24h interval
I am using the standard power supply
That is 1 more reason to try another one, many Homey power adapters had to be replaced.
So…
This has nothing to do with power supply. I’m using a 240W PSU, and it still happens.
But how much power can it deliver over regular USB? How clean is the 5V output?
It’s a USB-C, directly into the homey, so whatever the homey can pull, the PSU delivers
This thread is about the old Homey Pro, not the new one.
