I got it up and running, but what i want is not possible im told
In HA i have my broker and Zigbee2MQTT, but itās not possible with HOMEYā¦
Itās unclear what you want.
You would need Zigbee2MQTT running somewhere outside Homey, maybe as a container on a Raspberry Pi. I have it running as container on my Synology NAS.
You can then use the Zigbee2MQTT Homey App to map the devices from that to your Homey Pro.
Wouldnāt it be cool to run any container on your Homey Pro
Hello!
I want to setup dashboard for my homey, via Home assistant.
Iāve already done this in one place, where it works great. But if Iām going to do this again on another homey and another system, I canāt do it! Struggling to add MQTT to home assistant. What I can see the difference is that it says ābroker not runningā on this one which doesnāt work. What could I have done wrong?
This might be an obvious question, but what happens when you press āStart Brokerā?
Thatās a good question, haha. but nothing happens
And when you enable debug logging, does anything appear in the log?
Sadly, it looks like the source code of the broker isnāt public (anymore), so difficult to say why this is happening. All I can suggest is remove the app then try to install it again.
Strange! I have reinnstalled it 4 times now
In MQTT client this is the log:
Donāt know if this is related or not
Itās not related to the broker not starting.
I āfoundā the source, I think the only reason why this may happen is if thereās something already active on port 1883. Have you tried changing the port to something else, like 1886?
I now tried to uninstall again. Should it change to ābroker is runningā right away? Anyway, I get the same error in the log
It looks like the persistence database (where the broker stores some of its data) is broken. Try removing the app, then installing it again (not just reinstalling: remove it first, then install it again).
Thatās what I did now. Removed it. Restarted homey. Reinstalled, exactly the same! Strange, because itās up and running on my other homey.
Canāt figure out whatās wrong
Very strange, Iām out of ideas for now (it also doesnāt help that the broker isnāt handling certain errors, so if there are any errors that are causing the broker to not be able to start they arenāt being logged)
Instead of running MQTT Broker @ Homey, I run the Mosquitto Broker add-on @ Home Assistant and it works great.
Hereās a how to I wrote, in Dutch for now:
I translate easy with deepl.com or translate.google.com
Iāll try to add an English version of the tutorial in the near future.
Shit! Ducth is so hard. Even with translate
But Iāll try to see what I can do. An English version is greatly appreciated
There is nobody around that has access to the source code of this project? I really would like to add the web socket possibility or play around with that at least. But his other projects are live on github but this is not. would be great if we could work on this as well. Dont wanna start from scratch but If its not working I guess I have to
