Modbus TCP add to Homey Pro
Hi again
Hope 2023 has started well: Anyone have any solution to read modbus tcp to homey pro. And if so, how I should go about installation and what hardware I may need.
Sincerely, Lord Mats AF
I use it on my SolarEdge app but it is just way of communication. Not like a zigbee device.
You need to build an app around it. Add a device which read the modbus registers and you have to make capabilities of them.
Also, if SolarEdge is anything like Sofar, they use MODBUS RTU wrapped in a proprietary packet, so it’s not even real MODBUS IP.
The makes me wonder how many other MODBUS devices do a similar thing.
for solaredge I need to know the ip and modbus id plus use this doc to find all the registers https://knowledge-center.solaredge.com/sites/kc/files/sunspec-implementation-technical-note.pdf
then translate these register values back to float etc which is hard
