Since this week, controlling the hue bulbs via the homey app does not work anymore.
The message I get is “missing Capability Listener: onoff”.
nothing new has been added recently the only thing I can think of is that the modem has been rebooted 2 times by power outage
what can it be but more importantly what can be done about it. pretty hard now that no wireless switch can control any bulb anymore
i am not sure which app i use Philips Hue App versie 4.4.0.
the Message “missing Capability Listener” is not showing any more.
i moved Homey to the “meterkast” not sure the right word (fusebox) next to the router and after a while it seems to be better. can this has to something to do with de Google Nest Hello wireless (battery)? or with the attached wireless gong from Honeywell. maybe the signal interfered and blocked the homey signal to the hue Bridge? is that something to be aware of. For now my wife doesn’t trust the homey so i have to make a sustanibel soluition and i want Homey back in the living room
That’s what I wanted to know.
The Hue bridge communicates through wifi with Homey.
(The “Hue without the bridge” app works with zigbee).
So maybe you have some wifi issues.
By the way, the latest Hue app version mentions a fix for what it seems the problem you have.
Recently I also seem to have this problem. Athom’s Philips Hue app version is v5.5.0 and Homey is at v7.2.0.
Interestingly the hue bulbs turn on in the flows where they need to do so. But they don’t turn off anymore via flows.
While manually trying to toggle the bulbs via the Homey app, I indeed get an error saying Missing Capability Listener: onoff
Furthermore, if I toggle lights via the Hue android application, the state of the lights is correctly reflected in the Homey app…
To answer my own question. Athom support has looked into my issue and saw that Homey was unable to send data to the Hue bridge. Finally it seemed that the pihole in my network was interfering with the communication between Homey and the Hue bridge. Adding Homey and Hue bridge to be excluded from the pihole solved the issue!
