So, it’s high humidity here today and this has meant a few flows that measure increased humidity in a room have kicked in unnecessarily
I’d like to therefore include logic where I compare sensor reading to weather humidity + 5 (for example)
I can only seem to compare the tags directly tho without modifier - is there a way to do this?
DirkG
May 21, 2020, 12:41pm
2
You can calculate a new variable (humidity + 5).
Then you can use this new variable for comparison.
I hope I understand you correctly.
Odd, I tried that and it wasn’t letting me add anything into the box when I’d added the tag. Perhaps I wasn’t pressing in the right place!
Will try again
Found it - can’t do the logic in the middle, has to be set before hand!
DirkG
May 21, 2020, 1:25pm
5
You can do what you want, but without spaces.
Sorry, my bad explanation. You can’t do it mid flow (so you cant say IF a variable changed AND Tag > Humidity+5 THEN xyZ)
You have to set a logic variable to Humidity+5 first and compare against that new variable
DirkG
May 21, 2020, 1:31pm
7
Yes, that’s right, that’s what I mean with „new variable“.
