Humidity Target Range?
Hello everyone!
I would like to activate a socket when a sensor reaches a humidity of more than 55%.
I also created a corresponding flow. However, this does not trigger because the humidity is already over 55%. Is there a way to activate the flow when the value is not in a target range?
I’m looking forward to your help!
When…
-sensor X humidity changed
And…
-logic card [humidity tag from sensor X] is greater than 55
-socket Y is turned off
Then…
-turn on socket Y
This way, the flow gets triggered when the value changes from 70 to 71 for instance.
The AND part uses a logic card, here’s logic explained
Thanks a lot, mate!
