Logic calculate split a string
Hi Everyone,
I have a question about splitting a particular string.
The string that I have holds a date and time like this: 2024-03-16T14:00:00.000+01:00
Now I want to extract the day, the hour and the minutes.
I found in another post something like {{ 0+(“”.split(“-”)[1]) }} in this way I get the year (2024) and for the month only the (3) but not the day (16). I cannot get the time at all.
I don’t have a homey pro or a bridge.
Can somebody help me out to provide something that works?
You can also remove “0+” and you will get “01” in value. It depends on what you need.
Thanks for your help @Boris_Fers this worked :smiley:
Thank you very much for this - however, the variable it saves for me is in quotation marks when stored in the text variable. How do you save without them? Thanks in advance.
If you mean the “(a)Result” tag: it doesn’t contain quotation marks. Why do you think it does?
I also get quotation marks in the result variable.
I guess that flow card is broken then. You should contact Athom.
As an alternative you can use the equivalent flow card from the Better Logic Library.
Create a numeric value (learned from Robert :wink:)
