Little help with a broken flow
This flow doesnt seem to work at all, what did i do wrong?
thanks!
You can drag the flow cards down a bit in the and block to create multiple or conditions.
One might not nesesarily know about this.
Thanks! so i shoudl create 3 flows, one for each day`?
No, as Shakesbeard explained, there must be an or between the days:
Max 3 cards / group of cards. Max 2 or.
Thanks, never ever realized there was a drag feature
Yeah, same goes for the THEN block. You can implement a basic if THEN … ELSE by dragging there as well.
