Limitation of Zigbee devices?
Nop, that’s not thru…
it depends on your Homey model! and than it is either “a Lot direct children” or “up to 15 direct Clildren” nothing with around 20 …
Edit: A Lot for Homey Pro (Early 2023) and up to 15 for Homey Bridge AND Homey (Pro) Model (Early 2016-1019)
For Bridge: Creating-a-stable-Zigbee-network-with-Homey-Bridge and other Pro Creating-a-stable-Zigbee-network-with-Homey-Pro
Seeing your screenshot, it looks lik you have a Homey (Pro) Model (Early 2016-1019)
So up to 15 direct children…
Your Screenshot shows only 4 direct children! (#10 , #12, #15 and #19)
So That’s not the issue…
So you are probably out of range, or in range from a router that is already full (fe # 12 is busy with already serving 10 others at the moment you created the screenshot.)
Try adding more routers… or closer to… Homey / another Router with more slots free.
