Lifx lamp logic doesn' work
Does anyone understand why this flow doesn’t work? The lower flow works, but in the upper flow Nattlampa 1 cycles through the flow, and then it stays off.
What do you see when you start a test run with the first trigger card (“Right button was pressed”);
Next,
You can (temporary) add timeline notification card to each condition and action cards, with a meaningful description, to be able to see what happens in daily use.
Tip: usually “dim light Y to X” is turning a light on at the same time, so you can omit the “Turn light Y on” cards.
