Issues connecting to everything
Sorry for the general topic here. But its very much true…
I received my Homey yesterday. Set it up ok, and started adding devices… Thats when the fun started.
I have an existing Fibaro HC2-home with over 50 devices. So I need to reset the devices before adding to Homey. Thats ok. But when adding, I get drops or something in the pairing of z-wave devices that are all located 10cm from the homey (Fibaro Dimmer 2 and plug tested so far). Resulting in a unknown device in the developer view. Sometimes I manage to get it connected. But the range when trying to control the devices is about 4 meters in line of sight.
Im also having something that seems like network connectivity issues, causing homey to appear offline when using the app or the online developer tools. Tried at least 4 different locations for the homey. And also tried other power supplies…
I am on the latest stabel firmware, the wifi is velop 3 node mesh. And all other wifi/LAN devices in the house are working perfectly on the 500Mbit line.
A support case has been sent…
Any ideas?
Just managed to enable beta releases… And it seems the rc11 is giving a way more stable setup. Will try more later…
Do you use 2.4 or 5 ghz wifi?? (5 and mixed channel wifi will not work correct)
Plz use a desperate 2.4 channel
ok, set up a separate 2.4ghz network with a new name. went into recovery mode and reconnected to that network. But I am having the same issues still…
Homey goes offline all the time in Athom developer and adding of devices fail seemingly right before completion. The device is then added 10cm from the homey
Sent in a new log: 359DCEF42F
Network details from Homey desktop app:
{“address”:"::1",“netmask”:“ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff”,“family”:“IPv6”,“mac”:“00:00:00:00:00:00”,“scopeid”:0,“internal”:true,“cidr”:"::1/128"}],“wlan0”:[{“address”:“192.168.0.46”,“netmask”:“255.255.255.0”,“family”:“IPv4”,“mac”:“f0:45:da:23:04:0d”,“internal”:false,“cidr”:“192.168.0.46/24”},{“address”:“fe80::f245:daff:fe23:40d”,“netmask”:“ffff:ffff:ffff:ffff::”,“family”:“IPv6”,“mac”:“f0:45:da:23:04:0d”,“scopeid”:3,“internal”:false,“cidr”:“fe80::f245:daff:fe23:40d/64”}]}
Homey doesn’t support 5Ghz so it will only use 2.4 either way…
Tried one more time to add a dimmer. But again it failed just before completion. I also notice that the varning-sign for Athom cloud connectivity just went on before the error message came…
If possible, i´d like to look more into how the wifi connection is holding up… Is there any way to debug this?
That’s odd, I’m using the velop too and never needed to set up a separate 2.4ghz wifi and homey connects fine on the mixed channel just like my broadlink too even though both only supports 2.4ghz.
I’m using the velop in bridge mode though…
Did you open up anything in the velop to get access via developer?
nope. just setup velop as per the app.
Well this is getting funny… I started a full RF-sweep of my house with an immersionRC RF-meter that I just happened to have lying around… And after killing all devices that have RF transmitters in my house one by one, I think I might have found the culprit… An outdoor surveilance PoE camera (ESCAM Brick QD900)… But that is just one of 3 I have running… When re-plugging everything to power, except this one camera everything seems to be stable… And now the internet connection is 100%! yeah! Now to try adding devices again!
Great that you found this bastard and share it with us! Thanks! …
OK, even funnier… The issue is back…
I have disabled almost the entire LAN network. PoE switch is off. All cameras are down. But still the homey is going offline intermittently. I managed to get a zwave trace while adding a new node (node 19). And I also ran an internal ping test towards the homey to see if the network went down. But it did not… Ping was stable at around 14-70ms… As it is not a prioritized process, I am satisfied with getting a reply at all.
The developer page is going offline all the time.
The “not connected to atho cloud” message keeps coming.
And the fibaro dimmers are not adding propperly.
PS, all other internet connected devices in the house are working perfectly. And I can stream via the appletv just fine Also during the inclusions.
A new log has been sent in: B37D8A8967. Brains are fried for today… Guessing next step is to re-add he Fibaro HC2…
When adding without the fibaro-app, meaning via homey-Zwave, I get: vdevice.drivers.zwavebasic.pair.request_timeout or No Z-Wave device has been found.
Summary
Zwave trace:
[2018-10-16T19:50:17.763Z] Command[76] start: addNode
[2018-10-16T19:50:17.787Z] Command[76] status: addNode, status: ADD_NODE_STATUS_LEARN_READY
[2018-10-16T19:50:30.834Z] Command[76] status: addNode, status: ADD_NODE_STATUS_NODE_FOUND
[2018-10-16T19:50:30.934Z] Node[13]: Received application command for COMMAND_CLASS_BASIC, data: 0x03ff
[2018-10-16T19:50:30.934Z] Node[13]: [COMMAND_CLASS_BASIC] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:255}
[2018-10-16T19:50:31.466Z] Command[76] status: addNode, status: ADD_NODE_STATUS_ADDING_SLAVE
[2018-10-16T19:50:31.469Z] Node[13]: Received application command for COMMAND_CLASS_BASIC, data: 0x03ff
[2018-10-16T19:50:31.469Z] Node[13]: [COMMAND_CLASS_BASIC] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:255}
[2018-10-16T19:50:31.470Z] Node[13]: Received application command for COMMAND_CLASS_BASIC, data: 0x03ff
[2018-10-16T19:50:31.470Z] Node[13]: [COMMAND_CLASS_BASIC] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:255}
[2018-10-16T19:50:32.877Z] Command[76] status: addNode, status: ADD_NODE_STATUS_PROTOCOL_DONE
[2018-10-16T19:50:32.937Z] Command[76] status: addNode, status: ADD_NODE_STATUS_DONE
[2018-10-16T19:50:33.840Z] Command[76] status: addNode, status: INTERVIEW_SECURITY
[2018-10-16T19:50:33.841Z] Node[19]: [COMMAND_CLASS_SECURITY] [SECURITY_SCHEME_GET] {“type”:“Buffer”,“data”:[0]}
[2018-10-16T19:50:33.841Z] Node[19]: sendData to COMMAND_CLASS_SECURITY, params 0x0400
[2018-10-16T19:50:33.843Z] Command[77] start: sendData
[2018-10-16T19:50:33.843Z] ProcessSendData[30]: To node: 19 with data: 0x980400 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:33.900Z] Command[77] end: sendData
[2018-10-16T19:50:33.967Z] Node[19]: Received application command for COMMAND_CLASS_SECURITY, data: 0x0500
[2018-10-16T19:50:33.967Z] Node[19]: [COMMAND_CLASS_SECURITY] {“Supported Security Schemes (Raw)”:{“type”:“Buffer”,“data”:[0]},“Supported Security Schemes”:0}
[2018-10-16T19:50:33.969Z] Node[19]: [COMMAND_CLASS_SECURITY] [NETWORK_KEY_SET] {“type”:“Buffer”,“data”:[24,174,254,14,239,96,174,164,249,41,191,70,43,174,141,126]}
[2018-10-16T19:50:33.970Z] Node[19]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_GET] {“type”:“Buffer”,“data”:}
[2018-10-16T19:50:33.970Z] Node[19]: sendData to COMMAND_CLASS_SECURITY, params 0x40
[2018-10-16T19:50:33.971Z] Command[78] start: sendData
[2018-10-16T19:50:33.971Z] ProcessSendData[31]: To node: 19 with data: 0x9840 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:34.232Z] Node[19]: Received application command for COMMAND_CLASS_SECURITY, data: 0x804fe9d00ee93f32fd
[2018-10-16T19:50:34.232Z] Node[19]: [COMMAND_CLASS_SECURITY] {“Nonce byte”:{“type”:“Buffer”,“data”:[79,233,208,14,233,63,50,253]}}
[2018-10-16T19:50:34.244Z] Node[19]: [COMMAND_CLASS_SECURITY] [SECURITY_MESSAGE_ENCAPSULATION] {“type”:“Buffer”,“data”:[192,165,252,28,96,125,231,251,215,20,180,60,116,91,199,101,126,144,177,200,186,191,126,156,124,37,96,79,43,144,186,35,172,199,164,165]}
[2018-10-16T19:50:34.244Z] Node[19]: sendData to COMMAND_CLASS_SECURITY, params 0x81c0a5fc1c607de7fbd714b43c745bc7657e90b1c8babf7e9c7c25604f2b90ba23acc7a4a5
[2018-10-16T19:50:34.275Z] Command[78] end: sendData
[2018-10-16T19:50:34.275Z] Command[79] start: sendData
[2018-10-16T19:50:34.276Z] ProcessSendData[32]: To node: 19 with data: 0x9881c0a5fc1c607de7fbd714b43c745bc7657e90b1c8babf7e9c7c25604f2b90ba23acc7a4a5 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:34.374Z] Node[19]: Received application command for COMMAND_CLASS_SECURITY, data: 0x804fe9d00ee93f32fd
[2018-10-16T19:50:34.374Z] Node[19]: [COMMAND_CLASS_SECURITY] {“Nonce byte”:{“type”:“Buffer”,“data”:[79,233,208,14,233,63,50,253]}}
[2018-10-16T19:50:34.460Z] Node[19]: Received application command for COMMAND_CLASS_SECURITY, data: 0x802f6c18997ff96e67
[2018-10-16T19:50:34.461Z] Node[19]: [COMMAND_CLASS_SECURITY] {“Nonce byte”:{“type”:“Buffer”,“data”:[47,108,24,153,127,249,110,103]}}
[2018-10-16T19:50:34.524Z] Command[79] end: sendData
[2018-10-16T19:50:34.592Z] Node[19]: Received application command for COMMAND_CLASS_SECURITY, data: 0x802f6c18997ff96e67
[2018-10-16T19:50:34.592Z] Node[19]: [COMMAND_CLASS_SECURITY] {“Nonce byte”:{“type”:“Buffer”,“data”:[47,108,24,153,127,249,110,103]}}
[2018-10-16T19:50:34.658Z] Node[19]: Received application command for COMMAND_CLASS_SECURITY, data: 0x40
[2018-10-16T19:50:34.658Z] Node[19]: [COMMAND_CLASS_SECURITY] {}
[2018-10-16T19:50:34.660Z] Node[19]: [COMMAND_CLASS_SECURITY] [SECURITY_NONCE_REPORT] {“type”:“Buffer”,“data”:[1,209,7,68,160,29,137,128]}
[2018-10-16T19:50:34.660Z] Node[19]: sendData to COMMAND_CLASS_SECURITY, params 0x8001d10744a01d8980
[2018-10-16T19:50:34.661Z] Command[80] start: sendData
[2018-10-16T19:50:34.661Z] ProcessSendData[33]: To node: 19 with data: 0x988001d10744a01d8980 and txOptions: AUTO_ROUTE,EXPLORE
[2018-10-16T19:50:34.699Z] Command[80] end: sendData
[2018-10-16T19:50:35.360Z] Node[10]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x013003ffd1cb
[2018-10-16T19:50:35.361Z] Node[10]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[48]},“Command Class”:48,“Command (Raw)”:{“type”:“Buffer”,“data”:[3]},“Command”:3,“Data”:{“type”:“Buffer”,“data”:[255]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[209,203]},“Checksum”:53707}
[2018-10-16T19:50:35.376Z] Node[10]: [COMMAND_CLASS_SENSOR_BINARY] {“Sensor Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Sensor Value”:“detected an event”}
[2018-10-16T19:50:35.377Z] Node[10]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_SENSOR_BINARY, data 0x03ff
[2018-10-16T19:50:54.529Z] Command[76] status: addNode, status: INTERVIEW_CC
[2018-10-16T19:50:54.534Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x135e
[2018-10-16T19:50:54.536Z] Command[81] start: sendData
[2018-10-16T19:50:54.539Z] ProcessSendData[34]: To node: 19 with data: 0x86135e and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:54.652Z] Command[81] end: sendData
[2018-10-16T19:50:54.705Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x145e02
[2018-10-16T19:50:54.706Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[94]},“Requested Command Class”:94,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command Class Version”:2}
[2018-10-16T19:50:54.707Z] Command[76] status: addNode, status: INTERVIEW_CC_1_OF_22
[2018-10-16T19:50:54.708Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1320
[2018-10-16T19:50:54.708Z] Command[82] start: sendData
[2018-10-16T19:50:54.708Z] ProcessSendData[35]: To node: 19 with data: 0x861320 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:54.837Z] Command[82] end: sendData
[2018-10-16T19:50:54.902Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x142001
[2018-10-16T19:50:54.903Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[32]},“Requested Command Class”:32,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:54.903Z] Command[76] status: addNode, status: INTERVIEW_CC_2_OF_22
[2018-10-16T19:50:54.904Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1386
[2018-10-16T19:50:54.904Z] Command[83] start: sendData
[2018-10-16T19:50:54.905Z] ProcessSendData[36]: To node: 19 with data: 0x861386 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:54.951Z] Command[83] end: sendData
[2018-10-16T19:50:54.966Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x142001
[2018-10-16T19:50:54.967Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[32]},“Requested Command Class”:32,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:54.967Z] Command[76] status: addNode, status: INTERVIEW_CC_3_OF_22
[2018-10-16T19:50:54.968Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1372
[2018-10-16T19:50:54.968Z] Command[84] start: sendData
[2018-10-16T19:50:54.969Z] ProcessSendData[37]: To node: 19 with data: 0x861372 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:55.101Z] Command[84] end: sendData
[2018-10-16T19:50:55.117Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x142001
[2018-10-16T19:50:55.117Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[32]},“Requested Command Class”:32,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:55.117Z] Command[76] status: addNode, status: INTERVIEW_CC_4_OF_22
[2018-10-16T19:50:55.118Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1326
[2018-10-16T19:50:55.118Z] Command[85] start: sendData
[2018-10-16T19:50:55.119Z] ProcessSendData[38]: To node: 19 with data: 0x861326 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:55.200Z] Command[85] end: sendData
[2018-10-16T19:50:55.308Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x142603
[2018-10-16T19:50:55.309Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[38]},“Requested Command Class”:38,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[3]},“Command Class Version”:3}
[2018-10-16T19:50:55.309Z] Command[76] status: addNode, status: INTERVIEW_CC_5_OF_22
[2018-10-16T19:50:55.310Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x135a
[2018-10-16T19:50:55.310Z] Command[86] start: sendData
[2018-10-16T19:50:55.311Z] ProcessSendData[39]: To node: 19 with data: 0x86135a and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:55.365Z] Command[86] end: sendData
[2018-10-16T19:50:55.430Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x145a01
[2018-10-16T19:50:55.434Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[90]},“Requested Command Class”:90,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:55.434Z] Command[76] status: addNode, status: INTERVIEW_CC_6_OF_22
[2018-10-16T19:50:55.435Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1359
[2018-10-16T19:50:55.435Z] Command[87] start: sendData
[2018-10-16T19:50:55.435Z] ProcessSendData[40]: To node: 19 with data: 0x861359 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:55.479Z] Command[87] end: sendData
[2018-10-16T19:50:55.494Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x145a01
[2018-10-16T19:50:55.495Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[90]},“Requested Command Class”:90,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:55.495Z] Command[76] status: addNode, status: INTERVIEW_CC_7_OF_22
[2018-10-16T19:50:55.496Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1385
[2018-10-16T19:50:55.496Z] Command[88] start: sendData
[2018-10-16T19:50:55.496Z] ProcessSendData[41]: To node: 19 with data: 0x861385 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:55.608Z] Command[88] end: sendData
[2018-10-16T19:50:55.620Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x148502
[2018-10-16T19:50:55.620Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[133]},“Requested Command Class”:133,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command Class Version”:2}
[2018-10-16T19:50:55.621Z] Command[76] status: addNode, status: INTERVIEW_CC_8_OF_22
[2018-10-16T19:50:55.621Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1373
[2018-10-16T19:50:55.622Z] Command[89] start: sendData
[2018-10-16T19:50:55.624Z] ProcessSendData[42]: To node: 19 with data: 0x861373 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:55.695Z] Command[89] end: sendData
[2018-10-16T19:50:55.760Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x147301
[2018-10-16T19:50:55.760Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[115]},“Requested Command Class”:115,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:55.760Z] Command[76] status: addNode, status: INTERVIEW_CC_9_OF_22
[2018-10-16T19:50:55.761Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1398
[2018-10-16T19:50:55.761Z] Command[90] start: sendData
[2018-10-16T19:50:55.762Z] ProcessSendData[43]: To node: 19 with data: 0x861398 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:55.903Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x149801
[2018-10-16T19:50:55.904Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[152]},“Requested Command Class”:152,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:55.904Z] Command[76] status: addNode, status: INTERVIEW_CC_10_OF_22
[2018-10-16T19:50:55.905Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x137a
[2018-10-16T19:50:56.069Z] Command[90] end: sendData
[2018-10-16T19:50:56.070Z] Command[91] start: sendData
[2018-10-16T19:50:56.070Z] ProcessSendData[44]: To node: 19 with data: 0x86137a and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:56.090Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x149801
[2018-10-16T19:50:56.091Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[152]},“Requested Command Class”:152,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:56.091Z] Command[76] status: addNode, status: INTERVIEW_CC_11_OF_22
[2018-10-16T19:50:56.092Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1356
[2018-10-16T19:50:56.109Z] Command[91] end: sendData
[2018-10-16T19:50:56.109Z] Command[92] start: sendData
[2018-10-16T19:50:56.109Z] ProcessSendData[45]: To node: 19 with data: 0x861356 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:56.121Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x147a03
[2018-10-16T19:50:56.121Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[122]},“Requested Command Class”:122,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[3]},“Command Class Version”:3}
[2018-10-16T19:50:56.122Z] Command[76] status: addNode, status: INTERVIEW_CC_12_OF_22
[2018-10-16T19:50:56.124Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1370
[2018-10-16T19:50:56.137Z] Node[12]: Received application command for COMMAND_CLASS_SENSOR_MULTILEVEL, data: 0x05012200ed
[2018-10-16T19:50:56.138Z] Node[12]: [COMMAND_CLASS_SENSOR_MULTILEVEL] {“Sensor Type (Raw)”:{“type”:“Buffer”,“data”:[1]},“Sensor Type”:“Temperature (version 1)”,“Level (Raw)”:{“type”:“Buffer”,“data”:[34]},“Level”:{“Size”:2,“Scale”:0,“Precision”:1},“Sensor Value”:{“type”:“Buffer”,“data”:[0,237]},“Sensor Value (Parsed)”:23.7}
[2018-10-16T19:50:56.221Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x147a03
[2018-10-16T19:50:56.222Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[122]},“Requested Command Class”:122,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[3]},“Command Class Version”:3}
[2018-10-16T19:50:56.224Z] Command[76] status: addNode, status: INTERVIEW_CC_13_OF_22
[2018-10-16T19:50:56.224Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1331
[2018-10-16T19:50:56.354Z] Command[92] end: sendData
[2018-10-16T19:50:56.355Z] Command[93] start: sendData
[2018-10-16T19:50:56.355Z] ProcessSendData[46]: To node: 19 with data: 0x861370 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:56.419Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x145601
[2018-10-16T19:50:56.420Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[86]},“Requested Command Class”:86,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:56.420Z] Command[76] status: addNode, status: INTERVIEW_CC_14_OF_22
[2018-10-16T19:50:56.421Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1332
[2018-10-16T19:50:56.519Z] Command[93] end: sendData
[2018-10-16T19:50:56.519Z] Command[94] start: sendData
[2018-10-16T19:50:56.520Z] ProcessSendData[47]: To node: 19 with data: 0x861331 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:56.590Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x147001
[2018-10-16T19:50:56.590Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[112]},“Requested Command Class”:112,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:56.591Z] Command[76] status: addNode, status: INTERVIEW_CC_15_OF_22
[2018-10-16T19:50:56.591Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x138e
[2018-10-16T19:50:56.669Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x147001
[2018-10-16T19:50:56.669Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[112]},“Requested Command Class”:112,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:56.670Z] Command[76] status: addNode, status: INTERVIEW_CC_16_OF_22
[2018-10-16T19:50:56.670Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1360
[2018-10-16T19:50:56.717Z] Command[94] end: sendData
[2018-10-16T19:50:56.717Z] Command[95] start: sendData
[2018-10-16T19:50:56.718Z] ProcessSendData[48]: To node: 19 with data: 0x861332 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:56.746Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x143104
[2018-10-16T19:50:56.746Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[49]},“Requested Command Class”:49,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[4]},“Command Class Version”:4}
[2018-10-16T19:50:56.747Z] Command[76] status: addNode, status: INTERVIEW_CC_17_OF_22
[2018-10-16T19:50:56.749Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1375
[2018-10-16T19:50:56.932Z] Command[95] end: sendData
[2018-10-16T19:50:56.933Z] Command[96] start: sendData
[2018-10-16T19:50:56.933Z] ProcessSendData[49]: To node: 19 with data: 0x86138e and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:57.077Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x143203
[2018-10-16T19:50:57.078Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[50]},“Requested Command Class”:50,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[3]},“Command Class Version”:3}
[2018-10-16T19:50:57.078Z] Command[76] status: addNode, status: INTERVIEW_CC_18_OF_22
[2018-10-16T19:50:57.079Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1371
[2018-10-16T19:50:57.146Z] Command[96] end: sendData
[2018-10-16T19:50:57.146Z] Command[97] start: sendData
[2018-10-16T19:50:57.146Z] ProcessSendData[50]: To node: 19 with data: 0x861360 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:57.221Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x148e03
[2018-10-16T19:50:57.222Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[142]},“Requested Command Class”:142,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[3]},“Command Class Version”:3}
[2018-10-16T19:50:57.224Z] Command[76] status: addNode, status: INTERVIEW_CC_19_OF_22
[2018-10-16T19:50:57.224Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1327
[2018-10-16T19:50:57.241Z] Command[97] end: sendData
[2018-10-16T19:50:57.241Z] Command[98] start: sendData
[2018-10-16T19:50:57.242Z] ProcessSendData[51]: To node: 19 with data: 0x861375 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:57.344Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x146004
[2018-10-16T19:50:57.344Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[96]},“Requested Command Class”:96,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[4]},“Command Class Version”:4}
[2018-10-16T19:50:57.345Z] Command[76] status: addNode, status: INTERVIEW_CC_20_OF_22
[2018-10-16T19:50:57.345Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x1322
[2018-10-16T19:50:57.372Z] Command[98] end: sendData
[2018-10-16T19:50:57.372Z] Command[99] start: sendData
[2018-10-16T19:50:57.374Z] ProcessSendData[52]: To node: 19 with data: 0x861371 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:57.417Z] Command[99] end: sendData
[2018-10-16T19:50:57.418Z] Command[100] start: sendData
[2018-10-16T19:50:57.418Z] ProcessSendData[53]: To node: 19 with data: 0x861327 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:57.430Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x147502
[2018-10-16T19:50:57.430Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[117]},“Requested Command Class”:117,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[2]},“Command Class Version”:2}
[2018-10-16T19:50:57.431Z] Command[76] status: addNode, status: INTERVIEW_CC_21_OF_22
[2018-10-16T19:50:57.431Z] Node[19]: sendData to COMMAND_CLASS_VERSION, params 0x132b
[2018-10-16T19:50:57.607Z] Command[100] end: sendData
[2018-10-16T19:50:57.608Z] Command[101] start: sendData
[2018-10-16T19:50:57.608Z] ProcessSendData[54]: To node: 19 with data: 0x861322 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:57.771Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x142701
[2018-10-16T19:50:57.771Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[39]},“Requested Command Class”:39,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:57.772Z] Command[76] status: addNode, status: INTERVIEW_CC_22_OF_22
[2018-10-16T19:50:58.263Z] Command[76] status: addNode, status: INTERVIEW_MANUFACTURER_SPECIFIC
[2018-10-16T19:50:58.267Z] Node[19]: sendData to COMMAND_CLASS_MANUFACTURER_SPECIFIC, params 0x04
[2018-10-16T19:50:58.276Z] Command[101] end: sendData
[2018-10-16T19:50:58.276Z] Command[102] start: sendData
[2018-10-16T19:50:58.277Z] ProcessSendData[55]: To node: 19 with data: 0x7204 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:58.286Z] Node[19]: Received application command for COMMAND_CLASS_VERSION, data: 0x142201
[2018-10-16T19:50:58.286Z] Node[19]: [COMMAND_CLASS_VERSION] {“Requested Command Class (Raw)”:{“type”:“Buffer”,“data”:[34]},“Requested Command Class”:34,“Command Class Version (Raw)”:{“type”:“Buffer”,“data”:[1]},“Command Class Version”:1}
[2018-10-16T19:50:58.332Z] Command[102] end: sendData
[2018-10-16T19:50:58.431Z] Node[19]: Received application command for COMMAND_CLASS_MANUFACTURER_SPECIFIC, data: 0x05010f01021000
[2018-10-16T19:50:58.443Z] Node[19]: [COMMAND_CLASS_MANUFACTURER_SPECIFIC] {“Manufacturer ID”:{“value”:271,“name”:“MFG_ID_FIBARGROUP”},“Product Type ID”:{“value”:258},“Product ID”:{“value”:4096}}
[2018-10-16T19:50:58.445Z] Node[19]: sendData to COMMAND_CLASS_FIRMWARE_UPDATE_MD, params 0x01
[2018-10-16T19:50:58.446Z] Command[103] start: sendData
[2018-10-16T19:50:58.446Z] ProcessSendData[56]: To node: 19 with data: 0x7a01 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:58.508Z] Node[19]: Received application command for COMMAND_CLASS_MANUFACTURER_SPECIFIC, data: 0x05010f01021000
[2018-10-16T19:50:58.518Z] Node[19]: [COMMAND_CLASS_MANUFACTURER_SPECIFIC] {“Manufacturer ID”:{“value”:271,“name”:“MFG_ID_FIBARGROUP”},“Product Type ID”:{“value”:258},“Product ID”:{“value”:4096}}
[2018-10-16T19:50:58.608Z] Command[103] end: sendData
[2018-10-16T19:50:58.624Z] Node[19]: Received application command for COMMAND_CLASS_FIRMWARE_UPDATE_MD, data: 0x02010f01128bf9ff0100280112
[2018-10-16T19:50:58.626Z] Node[19]: [COMMAND_CLASS_FIRMWARE_UPDATE_MD] {“Manufacturer ID (Raw)”:{“type”:“Buffer”,“data”:[1,15]},“Manufacturer ID”:271,“Firmware 0 ID (Raw)”:{“type”:“Buffer”,“data”:[1,18]},“Firmware 0 ID”:274,“Firmware 0 Checksum (Raw)”:{“type”:“Buffer”,“data”:[139,249]},“Firmware 0 Checksum”:35833,“Firmware Upgradable (Raw)”:{“type”:“Buffer”,“data”:[255]},“Firmware Upgradable”:255,“Number of Firmware Targets (Raw)”:{“type”:“Buffer”,“data”:[1]},“Number of Firmware Targets”:1,“Max Fragment Size (Raw)”:{“type”:“Buffer”,“data”:[0,40]},"Max Fragment Size ":40,“Variant Group”:[{“Firmware ID (Raw)”:{“type”:“Buffer”,“data”:[1,18]},“Firmware ID”:274}]}
[2018-10-16T19:50:58.640Z] Command[76] status: addNode, status: INTERVIEW_ASSOCIATION
[2018-10-16T19:50:58.640Z] Node[19]: [COMMAND_CLASS_ASSOCIATION] [ASSOCIATION_GROUPINGS_GET] {“type”:“Buffer”,“data”:}
[2018-10-16T19:50:58.640Z] Node[19]: sendData to COMMAND_CLASS_ASSOCIATION, params 0x05
[2018-10-16T19:50:58.641Z] Command[104] start: sendData
[2018-10-16T19:50:58.641Z] ProcessSendData[57]: To node: 19 with data: 0x8505 and txOptions: AUTO_ROUTE,ACK,EXPLORE
[2018-10-16T19:50:58.695Z] Command[104] end: sendData
[2018-10-16T19:51:05.989Z] Node[10]: Received application command for COMMAND_CLASS_CRC_16_ENCAP, data: 0x01300300cf3b
[2018-10-16T19:51:05.989Z] Node[10]: [COMMAND_CLASS_CRC_16_ENCAP] {“Command Class (Raw)”:{“type”:“Buffer”,“data”:[48]},“Command Class”:48,“Command (Raw)”:{“type”:“Buffer”,“data”:[3]},“Command”:3,“Data”:{“type”:“Buffer”,“data”:[0]},“Checksum (Raw)”:{“type”:“Buffer”,“data”:[207,59]},“Checksum”:53051}
[2018-10-16T19:51:06.001Z] Node[10]: [COMMAND_CLASS_SENSOR_BINARY] {“Sensor Value (Raw)”:{“type”:“Buffer”,“data”:[0]},“Sensor Value”:“idle”}
[2018-10-16T19:51:06.002Z] Node[10]: Decapsulated frame from COMMAND_CLASS_CRC_16_ENCAP to COMMAND_CLASS_SENSOR_BINARY, data 0x0300
[2018-10-16T19:51:28.645Z] Command[76] end: addNode
[2018-10-16T19:51:44.836Z] Command[105] start: addNodeAbort
[2018-10-16T19:51:44.841Z] Command[105] end: addNodeAbort
[2018-10-16T19:52:01.103Z] Node[12]: Received application command for COMMAND_CLASS_BASIC, data: 0x03ff
[2018-10-16T19:52:01.104Z] Node[12]: [COMMAND_CLASS_BASIC] {“Value (Raw)”:{“type”:“Buffer”,“data”:[255]},“Value”:255}
[2018-10-16T19:52:12.463Z] Command[106] start: getNetworkTopology
[2018-10-16T19:52:12.758Z] Command[106] end: getNetworkTopology
[2018-10-16T19:52:12.917Z] Command[107] start: getFailedNodes
[2018-10-16T19:52:12.918Z] Command[108] start: isFailedNode
[2018-10-16T19:52:12.919Z] Command[109] start: isFailedNode
[2018-10-16T19:52:12.919Z] Command[110] start: isFailedNode
[2018-10-16T19:52:12.920Z] Command[111] start: isFailedNode
[2018-10-16T19:52:12.920Z] Command[112] start: isFailedNode
[2018-10-16T19:52:12.920Z] Command[113] start: isFailedNode
[2018-10-16T19:52:12.920Z] Command[114] start: isFailedNode
[2018-10-16T19:52:12.922Z] Command[108] end: isFailedNode
[2018-10-16T19:52:12.928Z] Command[109] end: isFailedNode
[2018-10-16T19:52:12.931Z] Command[110] end: isFailedNode
[2018-10-16T19:52:12.935Z] Command[111] end: isFailedNode
[2018-10-16T19:52:12.938Z] Command[112] end: isFailedNode
[2018-10-16T19:52:12.941Z] Command[113] end: isFailedNode
[2018-10-16T19:52:12.944Z] Command[114] end: isFailedNode
[2018-10-16T19:52:12.944Z] Command[107] end: getFailedNodes
Best contact athom about this. Email them.at support@athom.com
Athom does not read (everything) on this forum :wink:
Hello! Did you find any solution on this problem?
