I’m considering to replace some Light switches with a Fibaro Dimmer.
The reason why I want to use a Fibaro Dimmer and not a Fibaro Switch is because of not having a blue (zero) wire available at the wall mount switches.
The lightbulbs that are behind the current switches are Tradfri dimmable and color tunable GU10’’ s. So I already can control the color and dimlevel via Homey. Nevertheless I also want to be able to control it via actual switches.
Is it possible to use the Fibaro Dimmer as a button only?
In other words can I disable the dimming function of the dimmer. Such that, If I press a button then the dimming level of the Tradfri GU10’s is set by Homey and the dimmer itself does nothing (except triggering Homey)
