Hi there!
I have a dimmer and just bought a Fibaro Dimmer 2.
I want to control the lights with the Fibaro Dimmer, but I also want to control the light via the dimmer. See attached image of the wiring-options on the dimmer.
How should I connect the wires for getting it to work?
In my outlet, I have Lead (brown), Neutral (blue) and Ground (mix).
So far, it “works” with L in “L” and out through “output terminal”.
The dimmer, is plugged in via the S1 and the “output terminal”.
This means, that I can control them separately meaning, if I turn on the lights through Fibaro, I can not dim og turn off the light on the dimmer - and vice versa.
What to do???
