Cant seem to add devices any more, just get an eternally spinning “adding device” dialog, if I exit out the device is not shown on the app, and if I try to re-add I get “already added”.
I can “remove” (from z-wave dialog) and re start the process but the end result is always the same :’(
// Michael Medin
seems like you need to ‘delete’ the device from homey first. (maybe a faulty pairing caused it) Got to settings, zwave, remove a zwave device --> set device in pairing mode…
After it got gemoved, try to add it again…
Did you already perform a PtP (pull the plug for 12 minutes)?
Sometimes the Z-wave and/or Zigbee networks are not loaded correctly after a warm start. PtP should solve that.
I have done that numerous times, always ends up the same next time I add it again…
I had some kind of same issue yesterday with pairing Fibaro button. I had to remove device. There was A message to hold the button very close to Homey. The distance between button and Homey was 2nd time approx 10 cm. Second attempt did pair the button correctly.
Yeah, worked eventually when I had it closed to homey for me too… strange…
