I just got a more detailed log of what’s happening with the inclusion of the benext energy switch+.
2018-11-16T19:01:28.738Z Command[7] status: addNode, status: INTERVIEW_CC_1_OF_11
2018-11-16T19:01:28.739Z Node[6]: sendData to COMMAND_CLASS_VERSION, params 0x1386
2018-11-16T19:01:28.740Z Command[9] start: sendData
2018-11-16T19:01:28.741Z ProcessSendData[6]: To node: 6 with data: 0x861386 and txOptions: AUTO_ROUTE,ACK,EXPLORE
2018-11-16T19:01:28.769Z Command[9] end: sendData
2018-11-16T19:01:28.782Z Node[6]: Received application command for COMMAND_CLASS_VERSION, data: 0x148601
2018-11-16T19:01:28.783Z Node[6]: [COMMAND_CLASS_VERSION] {"Requested Command Class (Raw)":{"type":"Buffer","data":[134]},"Requested Command Class":134,"Command Class Version (Raw)":{"type":"Buffer","data":[1]},"Command Class Version":1}
2018-11-16T19:01:28.784Z Command[7] status: addNode, status: INTERVIEW_CC_2_OF_11
2018-11-16T19:01:28.784Z Node[6]: sendData to COMMAND_CLASS_VERSION, params 0x1332
2018-11-16T19:01:28.785Z Command[10] start: sendData
2018-11-16T19:01:28.785Z ProcessSendData[7]: To node: 6 with data: 0x861332 and txOptions: AUTO_ROUTE,ACK,EXPLORE
2018-11-16T19:01:33.794Z ProcessSendData[7]: Error: request_timeout
2018-11-16T19:01:33.796Z Command[10] end: sendData
2018-11-16T19:01:33.800Z Command[7] end: addNode
2018-11-16T19:01:52.982Z Command[11] start: addNodeAbort
2018-11-16T19:01:52.984Z Command[11] end: addNodeAbort
So what to do when Homey again decides to stop working? Manually remove all nodes and not ever touch the reset button on the xwave network again?
I also found a manual for the popp plugin dimmer, it states:
In order to include (add) a Z-Wave device to a network it **must be in factory default state.** Please make sure to reset the device into factory default. You can do this by performing an Exclusion operation as described below in the manual.
I can also confirm that after having excluded it from my previous controller and adding it to Homey that all of its settings were cleared. So my popp has certainly been reset, as would I expect it to be for the benext switch. Neither of those can be re-included. One with the mentioned error, the other only gives timeouts as if there is no device at all.
Another update, the popp was with 20 cm not close enough. when holding them within 1cm from one another I was able to add the popp dimmer back. I now have one included device. Then how does the reset for the BeNext Energy Swith + work? Mine does deviate from the manual as in it blinks twice instead of three times when entering learning mode.
Another update:
the popp is now 1meter from Homey and I cannot turn it on or off. So it’s included but not working. Now again within 1cm and still not working, similar issue as prior to zwave reset. A reboot might fix it for a short moment in time for some devices but not for others and then it again stops working.
I have excluded the popp and included it again. Now I get crappy but more consistent results.
3 meters line of sight works, 3 meters with 2 pieces of wood in between does not work.
