Integration Sonnen battery and Homey Pro flow not working
Hello!
I cant get my Homey pros flows to manage the Sonnen battery.
I assume that a Homey flow will show up in Sonnen Buddy. But nothing happens. When testing a flow it looks good in Homey but the battery do not operate. When putting the commands in SB manually the battery works. Please help. Other flows works in Homey
I can start and stop Sonnen from my Homey pro but as soon as I try to read the battery status in percent. It do not work. I can see the value in Sonnen Buddy. Yes I have same Token in Homey as in Sonnen Buddy. The one found in Mybattery (Sonnen). I have also changed to new Tokens all over but nothing helps. Could i be that there is a confusion in the system because I have (when I log in) seen that there is a Homey and a Homey Pro login?P
There are two Homey apps available which supports this device.
Sonnen App for Homey | Homey with no community topic
and
Sonnen Batterie App for Homey | Homey with community support topic: [APP][Pro] Sonnen Batterie
You should let the community know also which app you are using for them to better be able to help you.
Från Anders iPhone / From my iPhone
Hi @Anders_Ulenius
You can try the other “sonnen app”:
Please visit this forum for Q&A’s
One issue can be that your Sonnen Batterie is not on the same network as your Homey - auto-ip-discovery will not function then.
I already have the Sommen Batterie. What is the difference beteeen that and the Sonnen app?
I am the developer of the “other” app.
Okey I see!
Good work.
I updated the token in Sonnen batterie and in Homey.
Now more functions work although the functions for reading the battery like power to and from battery seems shaky.
Can you explain?
Hi @Anders_Ulenius - the app pulls values every ½ minute or so, the Sonnen-phone-app updates more frequently. If you would like more samples, you can visit settings for your Sonnen-device in Homey and adjust update-interval.
Is it possible to see if the batterij loads in the unballance market, you can trigger another device like a EV charger?
