Getting variable time into a flow for energy management
Short background, I have a Homey Pro for 2 days … I need a simple way ( I am no programmer) to insert the current time into a pictured flow for 30 mins on the Sonnen App
. This will stop my Sonnen battery from discharging when the smart charger (Zappi) is started by my Electric Supplier Octopus Energy. So do I need Timey App or something else ??
Any thoughts ! Help greatly appreciated
Hello, and welcome, Gareth.
If the time field takes 13:00 as valid starting time format:
Tap into the starting time field:
Tap on the ‘tag’ symbol on the right:
Enter time into the filter bar, and tap on the tag called “Time”:
This will enter the actual time into the card, when the flow gets triggered.
Thank you Peter for your response ! I only get a time wheel I don’t get a filter bar or I am being very stupid which is probable
YW!
No it’s not you, the app dev chose to use a time wheel as input, apparently tags cannot be used in that case.
Maybe, maybe when you ask him nicely, the app developer can add a duplicate card, which takes a string like 13:00, and which should take tags.
You can contact him by posting in the S. Batterie app topic!
but here you go:
Peter thank you for help !! I check out all the other Sonnen cards which looked the same and bingo a tag symbol was available so used it ! This is what I came up with … happy to have a critic on my 1st and biggest Energy flow ! Any better suggestions ?
I most definately agree :slight_smile:
