I have some Innr RC 210 in use that initiates switch on / off Aqara Single Switch Module T1 (No Neutral) with a connected lamp.
SInce some days or even weeks there is a strange behaviour. Lamp is off and I press one of the innr RC 210 to switch the lamp on, it works, but only some seconds later the lamp switches off again.
Any idea?
No neutral switches usually come with a capacitor that goes across the device’s live and neutral connections - preferably at the light fitting. Do you have one, and did you fit it? This is a no neutral switch I’ve got, and the images include a circuit diagram showing where the capacitor should go.
If you don’t have one, they are easy to get hold of. Here they are on Amazon UK, for example.
I think your answer does not match to my question.
I am not looking for any device. I got the Aqara Single Switch Module T1 (No Neutral) and it worked for several month until now.
I’m not recommending a different device, just pointing out that fitting a capacitor might fix your problem. The link to my switch includes a circuit diagram that shows how the capacitor should be fitted.
Sorry for my misunderstandig of that.
But when I use Alexa or Home App to switch the device Aqara Single Switch Module T1 (No Neutral) on, the device stays on
Any additional idea?
