IKEA Tredansen/praktlystring
Since yesterday my Tredansen/praktlystring are not working. From what I can see the ikes app has had some kind of update 3/3. Has it had any effect on my blinds?
This problem is for all my ikea blinds in my house from ikea. Any idea what might have caused this?
Hi Aldin, you can take a look at developer you will find posibilties to check the devices, like interview and ping to check if they are connected or not, as not working is not the same as not connected.
Hi Aldin,
I share my own experience…
hope it will help
I have 4 praktlystring blinds…
When I moved to my new place 1 year ago I started with a brand new homey box and few devices everything was ok…
My blinds was paired directly to my homey box
the first months I did add more and more IoT…
and at a certain point in time, my blinds stopped responding a good way…
more and more issues and every couple of days I had to pair again some blinds and homey…
I fixed that this summer this way :
I did unpaired my blinds from my Homey box
I used my Ikea dirigera hub to pair my 4 zigbee repeaters (the ones you received with the blinds) + my blinds
I share these devices with matter…
Everything works perfectly since
I can still build/use homey flows to open close my blinds…
I have Ikea remote directly paired in homey , they also works quick to open/close…
I can also control my blinds with voice and Apple HomeKit…
IMHO I believe that at a certain point my homey zigbee network was saturated…
I fixed that by creating a second zigbee managed with my Ikea box…(?)
not sure it’s accurate, I’m not a specialist
Regards
Hi Yann!
Big thanks for sharing! This was really the first time it happened. I saw that my Homey Pro got an update during the night and the next morning all my blinds was not working.
The thing I needed to do is to press the “down” button" on the blinds to wake them upp, after that, everything worked as usual.
I was just frustrated because I have about 20 blinds connected to Homey. I have also connected all the zigbee repeaters (the ones you received with the blinds) to Homey.
Right now, everything works. If it stops again, I will probably go for your solution :slight_smile:
