I got an ikea tradfri control socket, I tried to connect it several times, one time it homey saw it, but didn’t finish the install, since then Homey has not been able to see it.
Does anyone have tricks for this? I have homey 2cm away from it, but still no luck.
I have tried 1, 5, 10 cm and even 1 meter, but still no luck, it is very strange, mostly because one time it “almost” happened, except it never finished the installation.
i don’t have one of the buttons, but im starting to think that my homey has some problems, I delete some Zigbee devices, but now it won’t install new ones, so im doing another PTP
Now I have tried Ikea Trådfri control plug and the range extender, several Xiaomi devices, and nothing can install on the Homey, even with reinstallation of the software for them and restarting the Homey and PTP for 1 hour.
reinstalling the software for Ikea and Xiaomi was a bad idea, I lost all the connections, so might just have to try a Zigbee reset anyway, since nothing is connected
I have send a support ticket to Homey, reset of Zigbee network gives “Could not reset Zigbee: EBADF: bad file description, close: EBADF: bad file description, close" as en error, so that doesn’t work either, so either there’s a bug, or I did something really bad to my Homey trying to fix the problems
This message is normal or at least I had it to when resetting the ZigBee network.
But it indeed resets the network.
The problems with adding and removing devices is due to the limitations on the ZigBee part of homey.
This applies to the device not reachable messages.
But as discussed many times the bug ZigBee update should fix a lot of problems.
Reset Zigbee network, even though it gave an error
Uninstalled Ikea and Xiaomi apps, rebooted, installed them again and PTP overnight.
Now im all the sudden able to add devices again, even the 2 Ikea devices, some of the Xiaomi just need to have the battery removed for a minute, so im on to the big rebuild operation, but it looks promising.
