I can't update my Homey Pro 2023
I have tried to update my Homey Pro 2023 Ultra (updated Pi) the last couple of days but nothing happens.
I have restarted Homey, I have restarted the app and I have restarted my router/wifi mesh (TP Link Deco).
I use a Athom USB - ethernet adapter for my Homey Pro.
I have not cut the power to my HP 2023.
Does anyone else have issues?
I also have a HP 2023 at my moms house, that one have updated without issues.
Have you replaced the power adapter already? The included power adapter that’s included with the Homeys are known to cause strange issues over time.
If I remember correctly it should be the 5.2V adapter that I have, so it shouldn’t be the issue.
As an alternative, are you able to update connected to your computer via the USB tool?
Check this Knowledge Base article for instructions: Connect Homey Pro to a PC or Mac with USB.
I will give it a try even got back home tomorrow.
I have made some backup’s that way in the past.
Just to be clear :blush:: I am not referring to resettling or restoring your Homey. I am referring to the option to update Homey OS via that tool:
Yeah I got that. :slight_smile:
I had an adapter problem as well. I measured the voltage of the adapter which was below 5 V. After replacement everything was OK.
It still can be faulty or deteriorating. This has been an issue since Homey exists.
So always try another adapter to be sure.
The update has been going on for at least an hour, the first step is done so I guess that’s better then before. Still it feels strange that it takes this long.
When you have switched the USB adapter, which one have you used? I don’t think that any of the other I have will put out 5.2V just 5V or a lot higher.
It finaly made it.
Good to hear that you were able to perform the update :+1:.
Indeed, the ‘verifying’ step can take very look or will be shown indefinitely, while Homey has actually completed the update.
