Hue light turns on when Danalock opens every morning
Every morning when Homey opens up Danalock. Hue light in my guest room turns on. Hue answers to zigbee and Danalock is bound to Homekit/Bluetooth. No flows in common. Have reset both lock and light. Issue starts in a day or two again. Tried change to IKEA Tradlos light. Same. How is this possible. Can someone explain this to me. Getting tired of unsolved mysteries :wink:
Your light should have the activity log available, it would show what turned the light on.
This is from one of my lights:
For example the latest action was by the flow “aulan valot”.
And the action before that was controlled via Zigbee2MQTT app controls
and so on.
This should give you an idea what is controlling your light.
And, try to temporary disable systems, like Homekit/Bluetooth, to see if anything’s changed the next morning.
If Hue is also involving the Hue hub, shut that down as well, you’re very unspecific and generic about your system.
Start troubleshooting from the start!
It says started by Philips Hue. There are no flows, no triggers that is set to activate those bulbs. There is a manual button to the bulb (controlled by the Hue app). Thats it. I dont understand how it can turn on every morning 1 sec. after the lock. Even more strange is I can lock/unlock the Danalock how many times I want at any time of day and the bulb does not react. Only at the unlocking att 6am.
Little hard. I have over 100 Hue light controlled by Homey. The house will go completely dark. The only bulb that messes this up the one in the guest room. As I said earlier, I’ve tried IKEA bulb, but same problem. How I cannot understand. Going nuts
That usually means that an external source (outside of Homey) caused this.
But how is that possible. All my flows are controlled by Homey. But at every light that is turned on or off it says "Activated or Inactivated by Philips Hue. My original Philips Hue app doesnt have automations or on/off triggers. Everything is controlled by my Homey.
Also when a Hue light only gets dimmed, without a On or Off command, even when initiated by a flow, it says “Started by Hue”
You might be interested in installing the “Audit” app. It can record all Homey events at every log level, like ‘debug’. No flows needed, works out of the box.
Note: it’s a WIP, it might not work at certain Homeys
Ok, what additional information would it give me. I have a registrered ON in Homeys timeline. And yesterday I removed the bulb from Homey. But still it turned on this morning. This is getting really strange.
