@Caseda so we have to wait for webApi v3? ![]()
@Caseda @martijnpoppen Thanks finally, I’m able to see the mp3 path on HP2023.
@Seinuh change HOMEY_IP to your homeys ip ![]()
dissolved! thanks read or copy paste ![]()
Followed this tutorial, you’re as always awesome @martijnpoppen!
thank you very much for your tutorial
@RuudBinnendijk no idea. Contact Athom? Its their app
Thank you for your response Martijn!
Already did, but it will take 2-3 weeks for an answer…. Maybe someone else has the same problems (2 days ago there was an update: 10.0.5)
Groet van Ruud
@martijnpoppen
Fantastic! After bugging around with sharing sound files on OneDrive and not being able to get the URLs to work, I found this.
No sharing, works on Nests and Sonos both, even gets rid of the annoying Nest casting sound.
Again, fantastic. Thank you very much!
–edit 1: oops, the cast announcement sound is still there in the nest. I’ll try the trick with lowering and raising volume that I read about.
-edit 2: nope, can’t fix that. I don’t have any way to set the sound volume back to high after about half a second. Countdown timer only gives me full second increments. On top of that, the announcement sound doesn’t always play (only when there has been no casting for a wile) so I could end up muting the first half second of the actual sound I want to play…annoying google.
I just wanted to drop in and say that we’ve just launched an update that adds the “Cast soundboard sound” Flow card to the Chromecast App
